Vizio SmartCast Tablet Remote XR6M Battery Replacement
  1. Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: step 1, image 1 of 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: step 1, image 2 of 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement, Battery: step 1, image 3 of 3
    • Hold the device in one hand with the screen facing down.
    • Insert the plastic opening tool under the back panel on the side of the device.
    • Slide the plastic opening tool down the side of the device, then repeat this process on all four sides of the device until the back panel pops off.
    • You may hear a popping noise when you pry off the back panel.
    Ask FixBot
  2. Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 2, image 1 of 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 2, image 2 of 3 Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 2, image 3 of 3
    • Use a driver with the T5 bit to remove the 3mm screws attaching the narrow metal plate to the main board.
    Ask FixBot
  3. Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 3, image 1 of 2 Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 3, image 2 of 2
    • Slide the pointy end of the nylon spudger under the wires of the battery connector, and gently lift the wires away from the device, freeing the connector from the main board.
    Ask FixBot
  4. Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 4, image 1 of 2 Vizio SmartCast Tablet Remote XR6M Battery Replacement: step 4, image 2 of 2
    • To remove adhesive, insert the flat end of the plastic spudger under the battery. Slide it toward the top of the device until the battery pops free.
    • You may hear a popping noise when you pry off the battery.
    Ask FixBot
8 other people completed this guide.
tate campbell
460 Reputation
3 Guides authored
5 Guide Comments
Where did you find the replacement battery? I’ve looked everywhere, but the part numbers bring up nothing.
John - Reply Share
Same as that guy ^^^
gary goodnight - Reply Share
Yep me too , where can I get the battery ?????
Minus 300 points
Kyle Parker - Reply Share
More than 6 years and still no response on where to get the replacement 😔
Ryan Alexander - Reply Share
Donde consigo una bateriade esas?, mi tableta ya no prende quisiera ponerle una nueva!
אלונסו סנדובל - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 39
All Time: 2,542
