Vizio SmartCast Crave 360 Bottom Panel Replacement
    1. Vizio SmartCast Crave 360 Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 2 Vizio SmartCast Crave 360 Bottom Panel Replacement, Bottom Panel: step 1, image 2 of 2
      • Orient the speaker so that the bottom faces up.
      • Peel the rubber ring off of the bottom using the spudger.
      Ask FixBot
    2. Vizio SmartCast Crave 360 Bottom Panel Replacement: step 2, image 1 of 1
      • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
      Ask FixBot
    3. Vizio SmartCast Crave 360 Bottom Panel Replacement: step 3, image 1 of 2 Vizio SmartCast Crave 360 Bottom Panel Replacement: step 3, image 2 of 2
      • Lift the gray power port and move it to the side to reveal the bass.
      • Do not touch the wire that runs from the power port to the bottom of the bass component.
      Ask FixBot
Kristen Gismondi
109,172 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,303 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 41
All Time: 608
