Vizio SmartCast Crave 360 Battery Replacement
    1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: step 1, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: step 1, image 2 of 2
      • Orient the speaker so that the bottom faces up.
      • Peel the rubber ring off of the bottom using the spudger.
      Ask FixBot
    2. Vizio SmartCast Crave 360 Battery Replacement: step 2, image 1 of 1
      • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
      Ask FixBot
    3. Vizio SmartCast Crave 360 Battery Replacement: step 3, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement: step 3, image 2 of 2
      • Lift the gray power port and move it to the side to reveal the bass.
      • Do not touch the wire that runs from the power port to the bottom of the bass component.
      Ask FixBot
    1. Vizio SmartCast Crave 360 Battery Replacement, Bass: step 4, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: step 4, image 2 of 2
      • Remove the collar that wraps around the bass component.
      • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
      Ask FixBot
    2. Vizio SmartCast Crave 360 Battery Replacement: step 5, image 1 of 3 Vizio SmartCast Crave 360 Battery Replacement: step 5, image 2 of 3 Vizio SmartCast Crave 360 Battery Replacement: step 5, image 3 of 3
      • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
      • Take the bass component out of the speaker.
      • Disconnect the wiring that runs into the bass component.
      • The bass is now removed.
      Ask FixBot
    1. Vizio SmartCast Crave 360 Battery Replacement, Battery: step 6, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: step 6, image 2 of 2
      • Flip the speaker to access the top.
      • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
      • Remove the plastic disc from the speaker cage.
      Ask FixBot
    2. Vizio SmartCast Crave 360 Battery Replacement: step 7, image 1 of 1
      • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
      Ask FixBot
    3. Vizio SmartCast Crave 360 Battery Replacement: step 8, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement: step 8, image 2 of 2
      • Disconnect the wire that connects the motherboard to the battery.
      Ask FixBot
    4. Vizio SmartCast Crave 360 Battery Replacement: step 9, image 1 of 2 Vizio SmartCast Crave 360 Battery Replacement: step 9, image 2 of 2
      • Remove the motherboard and battery from the plastic cylinder.
      Ask FixBot
    5. Vizio SmartCast Crave 360 Battery Replacement: step 10, image 1 of 1
      • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
      Ask FixBot
    6. Vizio SmartCast Crave 360 Battery Replacement: step 11, image 1 of 1
      • Remove the motherboard from the battery.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Reply Share
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 71
All Time: 2,792
