Up to 20% off select tools
Vizio CT15 Keyboard Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
59
All Time:
1,375
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help users replace their Vizio CT15 keyboard when the whole keyboard is not responding.
    1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: step 1, image 1 of 2 Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: step 1, image 2 of 2
      • Turn the laptop off and remove all power cables.
      • Remove the six Phillips #0 screws.
      • Pull the back cover off.
      Ask FixBot
    1. Vizio CT15 Keyboard Replacement, Battery: step 2, image 1 of 1
      Ask FixBot
    2. Vizio CT15 Keyboard Replacement: step 3, image 1 of 2 Vizio CT15 Keyboard Replacement: step 3, image 2 of 2
      • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
      Ask FixBot
    1. Vizio CT15 Keyboard Replacement, Speakers: step 4, image 1 of 2 Vizio CT15 Keyboard Replacement, Speakers: step 4, image 2 of 2
      • Unplug the wire connecting the speakers to the motherboard.
      Ask FixBot
    2. Vizio CT15 Keyboard Replacement: step 5, image 1 of 2 Vizio CT15 Keyboard Replacement: step 5, image 2 of 2
      • Remove the four Phillips #0 screws.
      • Pull the speakers out to remove.
      Ask FixBot
    3. Vizio CT15 Keyboard Replacement: step 6, image 1 of 3 Vizio CT15 Keyboard Replacement: step 6, image 2 of 3 Vizio CT15 Keyboard Replacement: step 6, image 3 of 3
      • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
      • Pull the ribbon cables out of the ZIF connector.
      • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
      Ask FixBot
    4. Vizio CT15 Keyboard Replacement: step 7, image 1 of 2 Vizio CT15 Keyboard Replacement: step 7, image 2 of 2
      • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
      Ask FixBot
    1. Vizio CT15 Keyboard Replacement, CPU Fan: step 8, image 1 of 2 Vizio CT15 Keyboard Replacement, CPU Fan: step 8, image 2 of 2
      • Unplug the fan from the motherboard.
      Ask FixBot
    2. Vizio CT15 Keyboard Replacement: step 9, image 1 of 2 Vizio CT15 Keyboard Replacement: step 9, image 2 of 2
      • Remove the three Phillips #0 screws.
      • Pull the fan out to remove.
      Ask FixBot
    1. Vizio CT15 Keyboard Replacement, Keyboard: step 10, image 1 of 2 Vizio CT15 Keyboard Replacement, Keyboard: step 10, image 2 of 2
      • Remove the four Philips #0 screws from the heatsink.
      • Pull up and out to remove the heatsink from the laptop.
      Ask FixBot
    2. Vizio CT15 Keyboard Replacement: step 11, image 1 of 2 Vizio CT15 Keyboard Replacement: step 11, image 2 of 2
      • Remove the eight Phillips #0 screws from the motherboard.
      • Lift the motherboard up and out to remove it from the laptop.
      Ask FixBot
    3. Vizio CT15 Keyboard Replacement: step 12, image 1 of 1
      • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
      Ask FixBot
    4. Vizio CT15 Keyboard Replacement: step 13, image 1 of 3 Vizio CT15 Keyboard Replacement: step 13, image 2 of 3 Vizio CT15 Keyboard Replacement: step 13, image 3 of 3
      • Use a metal spudger to carefully push the keyboard out of place.
      • Carefully flip the laptop over and pull the keyboard out.
      Ask FixBot
3 other people completed this guide.
Author
with
jalon
115 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 59
All Time: 1,375
