Vivotek FD8169 Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
49
All Time:
921
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Vivotek FD8169 Motherboard Replacement, Dome Cover: step 1, image 1 of 1
      • Loosen the outside screw.
      Ask FixBot
    2. Vivotek FD8169 Motherboard Replacement: step 2, image 1 of 1
      • Press down on the side button, and lift up the top dome.
      Ask FixBot
    1. Vivotek FD8169 Motherboard Replacement, Camera Module: step 3, image 1 of 1
      • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
      Ask FixBot
    2. Vivotek FD8169 Motherboard Replacement: step 4, image 1 of 1
      • Lift off the camera base from the motherboard.
      Ask FixBot
    3. Vivotek FD8169 Motherboard Replacement: step 5, image 1 of 1
      • Unscrew the cord from the motherboard.
      • Unplug the remaining connection.
      Ask FixBot
    4. Vivotek FD8169 Motherboard Replacement: step 6, image 1 of 1
      • Unscrew the camera from the camera base with a hex screwdriver on both sides.
      Ask FixBot
    5. Vivotek FD8169 Motherboard Replacement: step 7, image 1 of 1
      • Pull the camera out from the camera base.
      Ask FixBot
    1. Vivotek FD8169 Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
      Ask FixBot
    2. Vivotek FD8169 Motherboard Replacement: step 9, image 1 of 1
      • Once the screws are gone, lift the faulty motherboard and replace with a new one.
      Ask FixBot
Artem Dudko
159 Reputation
1 Guide authored
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 49
All Time: 921
