Up to 20% off select tools
Vivotek FD8169 Camera Module Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
72
All Time:
991
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Vivotek FD8169 Camera Module Replacement, Dome Cover: step 1, image 1 of 1
      • Loosen the outside screw.
      Ask FixBot
    2. Vivotek FD8169 Camera Module Replacement: step 2, image 1 of 1
      • Press down on the side button, and lift up the top dome.
      Ask FixBot
    1. Vivotek FD8169 Camera Module Replacement, Camera Module: step 3, image 1 of 1
      • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
      Ask FixBot
    2. Vivotek FD8169 Camera Module Replacement: step 4, image 1 of 1
      • Lift off the camera base from the motherboard.
      Ask FixBot
    3. Vivotek FD8169 Camera Module Replacement: step 5, image 1 of 1
      • Unscrew the cord from the motherboard.
      • Unplug the remaining connection.
      Ask FixBot
    4. Vivotek FD8169 Camera Module Replacement: step 6, image 1 of 1
      • Unscrew the camera from the camera base with a hex screwdriver on both sides.
      Ask FixBot
    5. Vivotek FD8169 Camera Module Replacement: step 7, image 1 of 1
      • Pull the camera out from the camera base.
      Ask FixBot
2 other people completed this guide.
Author
with
Logan Bento
169 Reputation
1 Guide authored
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Member of UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 991
