Vivo x60 Pro Plus Battery Replacement
    1. Ask FixBot
    2. Vivo x60 Pro Plus Battery Replacement: step 2, image 1 of 1
      • Remove these screws. The red ones are all equal length/size, where the blue ones are shorter ones. You need a PH000 screwdriver for these.
      Ask FixBot
    3. Vivo x60 Pro Plus Battery Replacement: step 3, image 1 of 1
      • Remove this plate and disconnect this connector.
      Ask FixBot
    4. Vivo x60 Pro Plus Battery Replacement: step 4, image 1 of 2 Vivo x60 Pro Plus Battery Replacement: step 4, image 2 of 2
      • Now this black plate with the antenna is free and can be removed. This will uncover one of two battery connectors that we need to get access to. You can see this part in action here https://youtu.be/yAt_VJIhXXk?si=jZaeFsT2...
      Ask FixBot
    5. Vivo x60 Pro Plus Battery Replacement: step 5, image 1 of 1
      • (Notice: Phone has been turned by 180 degrees)
      • Unscrew the right plate to uncover the second battery connector
      • Disconnect both battery connectors with a spudger (plastic)
      Ask FixBot
    6. Vivo x60 Pro Plus Battery Replacement: step 6, image 1 of 1
      • Peel these transparent tapes off and move them towards the outside of the phone (you can't remove them entirely, as they are glued to the device). Do this for both upper and lower transparent tape like indicated by the arrows.
      • The green transparent tape should stay where it is for now
      Ask FixBot
    7. Vivo x60 Pro Plus Battery Replacement: step 7, image 1 of 1
      Ask FixBot
    8. Vivo x60 Pro Plus Battery Replacement: step 8, image 1 of 1
      • Done. Replace now your battery and perform the steps in reverse to assemble your device. The back cover is held onto the device with glue, so simply pushing it back in place should keep it there.
      • Here is a picture of the original battery
      Ask FixBot
Visible Panda
194 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 125
All Time: 1,818
