Vivitar XO 7 Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
93
All Time:
600
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you are experiencing problems with your device's front or rear camera, this guide will help you to remove and replace the faulty part. Both cameras are connected and are removed simultaneously.
Tools
    1. Vivitar XO 7 Camera Replacement, Back Cover: step 1, image 1 of 1
      • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
      Ask FixBot
    2. Vivitar XO 7 Camera Replacement: step 2, image 1 of 1
      • With the plastic opening tools, pry open the back cover.
      Ask FixBot
    3. Vivitar XO 7 Camera Replacement: step 3, image 1 of 1
      • Remove the back cover from the tablet.
      Ask FixBot
    1. Vivitar XO 7 Camera Replacement, Battery: step 4, image 1 of 2 Vivitar XO 7 Camera Replacement, Battery: step 4, image 2 of 2
      • Peel off the black pieces of tape from the internal components.
      Ask FixBot
    2. Vivitar XO 7 Camera Replacement: step 5, image 1 of 2 Vivitar XO 7 Camera Replacement: step 5, image 2 of 2
      • Carefully remove the battery from the tablet.
      Ask FixBot
    3. Vivitar XO 7 Camera Replacement: step 6, image 1 of 2 Vivitar XO 7 Camera Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
      Ask FixBot
    1. Vivitar XO 7 Camera Replacement, Camera: step 7, image 1 of 1
      • Peel off black tape that is holding the camera in place.
      Ask FixBot
    2. Vivitar XO 7 Camera Replacement: step 8, image 1 of 1
      • Carefully disconnect the ribbon cables from the motherboard.
      Ask FixBot
    3. Vivitar XO 7 Camera Replacement: step 9, image 1 of 2 Vivitar XO 7 Camera Replacement: step 9, image 2 of 2
      Buy
      • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
      Ask FixBot
Braanah Craig
386 Reputation
2 Guides authored
USF Tampa, Team 11-1, Blackwell Winter 2015 Member of USF Tampa, Team 11-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 93
All Time: 600
