Vivitar Vivicam T027 Screen Replacement
  1. Vivitar Vivicam T027 Screen Replacement, Screen: step 1, image 1 of 2 Vivitar Vivicam T027 Screen Replacement, Screen: step 1, image 2 of 2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
    Ask FixBot
  2. Vivitar Vivicam T027 Screen Replacement: step 2, image 1 of 1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
    Ask FixBot
  3. Vivitar Vivicam T027 Screen Replacement: step 3, image 1 of 2 Vivitar Vivicam T027 Screen Replacement: step 3, image 2 of 2
    • Separate the front piece of the camera from the back to reveal the motherboard.
    Ask FixBot
  4. Vivitar Vivicam T027 Screen Replacement: step 4, image 1 of 1
    • Remove the plastic silver strip from the front case of the camera.
    Ask FixBot
  5. Vivitar Vivicam T027 Screen Replacement: step 5, image 1 of 1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
    Ask FixBot
  6. Vivitar Vivicam T027 Screen Replacement: step 6, image 1 of 1
    • Remove the black plastic cover to reveal the newly exposed screen.
    Ask FixBot
  7. Vivitar Vivicam T027 Screen Replacement: step 7, image 1 of 2 Vivitar Vivicam T027 Screen Replacement: step 7, image 2 of 2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
    Ask FixBot
Nicole Knoebel
270 Reputation
2 Guides authored
Marist, Team 15-13, Laflen Spring 2015 Member of Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Members
3 Guides authored
2 Guide Comments
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Reply Share
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 41
All Time: 1,499
