Vivitar Vivicam T027 Power Button Replacement
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: step 1, image 1 of 2 Vivitar Vivicam T027 Power Button Replacement, Power Button: step 1, image 2 of 2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
    Ask FixBot
  2. Vivitar Vivicam T027 Power Button Replacement: step 2, image 1 of 1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
    Ask FixBot
  3. Vivitar Vivicam T027 Power Button Replacement: step 3, image 1 of 2 Vivitar Vivicam T027 Power Button Replacement: step 3, image 2 of 2
    • Separate the front and the back of the camera completely to expose the motherboard.
    Ask FixBot
  4. Vivitar Vivicam T027 Power Button Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
    Ask FixBot
  5. Vivitar Vivicam T027 Power Button Replacement: step 5, image 1 of 2 Vivitar Vivicam T027 Power Button Replacement: step 5, image 2 of 2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
    Ask FixBot
Dana
110 Reputation
1 Guide authored
Marist, Team 15-13, Laflen Spring 2015 Member of Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,326
