Vivitar DVR 781HD Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
93
All Time:
1,141
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide provides step by step instructions for removal of the display from the 781HD DVR camcorder. Replacement of the display requires soldering and should only be considered if the reader is comfortable with soldering on small electrical boards.
Tools
    1. Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 1 of 3 Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 2 of 3 Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 3 of 3
      • Begin with the camcorder lens up on a clear working surface.
      • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
      Ask FixBot
    2. Vivitar DVR 781HD Screen Replacement: step 2, image 1 of 1
      • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
      Ask FixBot
    3. Vivitar DVR 781HD Screen Replacement: step 3, image 1 of 3 Vivitar DVR 781HD Screen Replacement: step 3, image 2 of 3 Vivitar DVR 781HD Screen Replacement: step 3, image 3 of 3
      • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
      • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
      Ask FixBot
    1. Vivitar DVR 781HD Screen Replacement, Motherboard: step 4, image 1 of 2 Vivitar DVR 781HD Screen Replacement, Motherboard: step 4, image 2 of 2
      • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
      Ask FixBot
    2. Vivitar DVR 781HD Screen Replacement: step 5, image 1 of 1
      • Gently lift the motherboard, handling it by the edges.
      Ask FixBot
    1. Vivitar DVR 781HD Screen Replacement, Screen: step 6, image 1 of 2 Vivitar DVR 781HD Screen Replacement, Screen: step 6, image 2 of 2
      • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
      Ask FixBot
    2. Vivitar DVR 781HD Screen Replacement: step 7, image 1 of 2 Vivitar DVR 781HD Screen Replacement: step 7, image 2 of 2
      • Turn the motherboard and screen over.
      • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
      Ask FixBot
    3. Vivitar DVR 781HD Screen Replacement: step 8, image 1 of 1
      • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
      Ask FixBot
2 other people completed this guide.
Nathan McDaniel
592 Reputation
3 Guides authored
IUPUI, Team 54-6, Wilson Spring 2016 Member of IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 93
All Time: 1,141
