Up to 20% off select tools
Vitamix 5200 Drive Socket Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
10
Past 7 Days:
69
Past 30 Days:
287
All Time:
5,288
Comments: 4
4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Very easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn or damaged Vitamix 5200 Drive Socket.
The drive socket is one of the most vital parts of the Vitamix blender. If it experiences too much damage the teeth will be unable to catch the blender blade which will result in an unusable blender.
Before using this guide be sure to confirm that the drive socket is indeed the source of the issue by checking the blender jar blade as well as the motor. Once it is clear that it's the drive socket that needs replacement, order your replacement part and follow these simple steps to restore your Vitamix blender.
Steps 4 and 7 will require the use of a 5/64ths Allen wrench. Generally, one will come packaged with your replacement drive socket.
Before beginning be sure to disconnect the blender from any external power source.
    1. Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 1 of 3 Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 2 of 3 Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 3 of 3
      • Unplug the motor from its external power source.
      • Remove the blender jar from the motor base.
      Ask FixBot
    2. Vitamix 5200 Drive Socket Replacement: step 2, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 2, image 2 of 2
      • Lift up and remove the rubber jar pad surrounding the drive socket.
      Ask FixBot
    3. Vitamix 5200 Drive Socket Replacement: step 3, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 3, image 2 of 2
      • Align the Vitamix logo and arrow to the small hole at the base of the drive socket.
      Ask FixBot
    4. Vitamix 5200 Drive Socket Replacement: step 4, image 1 of 3 Vitamix 5200 Drive Socket Replacement: step 4, image 2 of 3 Vitamix 5200 Drive Socket Replacement: step 4, image 3 of 3
      • Using a 5/64th Allen wrench, place it at a 45-degree angle into the small hole and twist leftward to loosen the drive socket.
      • Only loosen to the point of freeing the socket. Loosen too much and you risk dropping the screw into the motor.
      Ask FixBot
    5. Vitamix 5200 Drive Socket Replacement: step 5, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 5, image 2 of 2
      • Remove the old drive socket.
      Ask FixBot
    6. Vitamix 5200 Drive Socket Replacement: step 6, image 1 of 3 Vitamix 5200 Drive Socket Replacement: step 6, image 2 of 3 Vitamix 5200 Drive Socket Replacement: step 6, image 3 of 3
      • Place the new drive socket on the square nut.
      • Realign the logo and arrow with the small hole at the sockets base.
      Ask FixBot
    7. Vitamix 5200 Drive Socket Replacement: step 7, image 1 of 1
      • Twist the Allen wrench rightward to tighten the new drive socket into place.
      Ask FixBot
6 other people completed this guide.
Author
with
Courtland Brown
335 Reputation
1 Guide authored
4 Guide Comments
Excelente explicativo. Normalmente a estos equipos hay que observar que las dos llaves estén en buenas condiciones, sobre todo el pulsador, la mayoría de las veces es el problema principal que el equipo funcione mal. Saludos EXITOS
Carlos Soto - Reply Share
Très pratique
Hamissou Nhour - Reply Share
What should I do when the motor stocked. Not rolling but making a buzz sound.
Fresh Swag - Reply Share
You can use a 2mm hex key if you don't have a 5/64" hex key as they are almost exactly the same size. Note also that the angle for hex key insertion is not 45° - it's closer to 30° from the horizontal plane. If you have a ball-end hex key of either size it is easier to fit the hex key. Also, if you back out the cap screw too far and drop it on the floor and the dog swallows it, the replacement size is a #2-56 x 3/16" stainless steel cap screw.
jgealy - Reply Share
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 287
All Time: 5,288
