Up to 20% off select tools
Visual Land Prestige Pro 7D Camera Replacement
Views: 1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
24
Past 30 Days:
100
All Time:
1,006
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the simple steps to replacing the front-facing camera.
    1. Visual Land Prestige Pro 7D Camera Replacement, Back Panel: step 1, image 1 of 1
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      Ask FixBot
    2. Visual Land Prestige Pro 7D Camera Replacement: step 2, image 1 of 1
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      Ask FixBot
    1. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: step 3, image 1 of 2 Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: step 3, image 2 of 2
      • Remove the black pad on the back of the camera by peeling it off.
      Ask FixBot
    2. Visual Land Prestige Pro 7D Camera Replacement: step 4, image 1 of 1
      • With the bottom of the device facing away from you, pull the camera out of its black housing.
      • The camera will come right out when you lift with your fingers.
      Ask FixBot
    3. Visual Land Prestige Pro 7D Camera Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tweezers to lift the grey connector, connecting the camera ribbon to the circuit board, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
      Ask FixBot
Author
with
Brandon Kodama
229 Reputation
1 Guide authored
Cal Poly, Team 10-41, Amido Fall 2014 Member of Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 24
Past 30 Days: 100
All Time: 1,006
