Visual Land Prestige 7L Front Facing Camera Replacement
    1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: step 1, image 1 of 2 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 8mm Phillips Head screws located at the bottom of your device.
      Ask FixBot
    2. Visual Land Prestige 7L Front Facing Camera Replacement: step 2, image 1 of 3 Visual Land Prestige 7L Front Facing Camera Replacement: step 2, image 2 of 3 Visual Land Prestige 7L Front Facing Camera Replacement: step 2, image 3 of 3
      • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
      • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
      • Finish unsnapping each plastic piece holding the device together along the bottom.
      Ask FixBot
    3. Visual Land Prestige 7L Front Facing Camera Replacement: step 3, image 1 of 3 Visual Land Prestige 7L Front Facing Camera Replacement: step 3, image 2 of 3 Visual Land Prestige 7L Front Facing Camera Replacement: step 3, image 3 of 3
      • Move the spudger down the rest of the case, separating each side, and finally the top.
      • Pull the back off and place it to the side.
      • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
      Ask FixBot
    1. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 2 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: step 4, image 2 of 2
      • Remove the adhesive padding.
      Ask FixBot
    2. Visual Land Prestige 7L Front Facing Camera Replacement: step 5, image 1 of 2 Visual Land Prestige 7L Front Facing Camera Replacement: step 5, image 2 of 2
      • Unclip the connector that attaches the camera to the motherboard.
      • For more information on unclipping connectors see this How To Guide
      • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
      • Gently pop the camera out of the connector and off the case.
      Ask FixBot
Greg Azzalina
263 Reputation
1 Guide authored
Penn State, Team 2-25, Kaschak Winter 2015 Member of Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 506
