Visual Land Prestige 10 Motherboard Replacement
    1. Visual Land Prestige 10 Motherboard Replacement, Back Case: step 1, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement, Back Case: step 1, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement, Back Case: step 1, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
      • All screws throughout this guide are the same 3mm size.
      Ask FixBot
    2. Visual Land Prestige 10 Motherboard Replacement: step 2, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement: step 2, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement: step 2, image 3 of 3
      • Using the spudger, create a small opening to be used to open the back case.
      • While holding the case open, insert the plastic opening tool to get a larger opening.
      • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
      Ask FixBot
    3. Visual Land Prestige 10 Motherboard Replacement: step 3, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement: step 3, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement: step 3, image 3 of 3
      • now that the case is open, carefully remove the speakers and set aside.
      Ask FixBot
    4. Visual Land Prestige 10 Motherboard Replacement: step 4, image 1 of 2 Visual Land Prestige 10 Motherboard Replacement: step 4, image 2 of 2
      Buy
      • Gently remove the speakers from the back case with tweezers and set the case aside.
      Ask FixBot
    1. Visual Land Prestige 10 Motherboard Replacement, Battery: step 5, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement, Battery: step 5, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement, Battery: step 5, image 3 of 3
      • Remove yellow tape from surrounding components.
      Ask FixBot
    2. Visual Land Prestige 10 Motherboard Replacement: step 6, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement: step 6, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement: step 6, image 3 of 3
      • insert the spudger and gently work around and underneath the battery.
      • With the battery separated from the LCD Display, set it aside.
      • The battery is held down by very strong adhesive.
      Ask FixBot
    3. Visual Land Prestige 10 Motherboard Replacement: step 7, image 1 of 1
      • Desolder and remove the 2 wires from the motherboard.
      • Use caution when desoldering to avoid damage to yourself or to the components.
      Ask FixBot
    1. Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: step 8, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: step 8, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: step 8, image 3 of 3
      • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
      • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
      • Gently grip and pull up the front camera, covered by protective adhesive foam.
      • Set aside the Camera housing.
      Ask FixBot
    1. Visual Land Prestige 10 Motherboard Replacement, Motherboard: step 9, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement, Motherboard: step 9, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement, Motherboard: step 9, image 3 of 3
      Buy
      • Locate the LCD Connector.
      • Using tweezers, grip the small black tab connected to the white plastic.
      • Gently lift the tab towards you until it clicks.
      • Remove the connector by pulling straight out, gripping the black connector head.
      Ask FixBot
    2. Visual Land Prestige 10 Motherboard Replacement: step 10, image 1 of 3 Visual Land Prestige 10 Motherboard Replacement: step 10, image 2 of 3 Visual Land Prestige 10 Motherboard Replacement: step 10, image 3 of 3
      • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
      • Lift the tab towards you until you feel an audible click.
      • Gently remove the connector by pulling straight out, gripping the black connector head.
      Ask FixBot
    3. Visual Land Prestige 10 Motherboard Replacement: step 11, image 1 of 2 Visual Land Prestige 10 Motherboard Replacement: step 11, image 2 of 2
      • Gently lift up the WiFi antenna and set aside.
      Ask FixBot
    4. Visual Land Prestige 10 Motherboard Replacement: step 12, image 1 of 2 Visual Land Prestige 10 Motherboard Replacement: step 12, image 2 of 2
      • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
      • Gently lift up on the controller and leave it hanging loose.
      Ask FixBot
    5. Visual Land Prestige 10 Motherboard Replacement: step 13, image 1 of 2 Visual Land Prestige 10 Motherboard Replacement: step 13, image 2 of 2
      • Remove screws located on motherboard.
      • Place on magnetic mat and label them
      • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
      Ask FixBot
6 other people completed this guide.
1 Guide Comment
I just received my tablet. and it will not allow me to set up a password. It keeps asking for previous password. I have done a hard reset but have not been able to set up my tablet.
John Jefferson - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,047
