Visual Land Prestige 10 Front Facing Camera Replacement
    1. Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: step 1, image 1 of 3 Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: step 1, image 2 of 3 Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: step 1, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
      • All screws throughout this guide are the same 3mm size.
      Ask FixBot
    2. Visual Land Prestige 10 Front Facing Camera Replacement: step 2, image 1 of 3 Visual Land Prestige 10 Front Facing Camera Replacement: step 2, image 2 of 3 Visual Land Prestige 10 Front Facing Camera Replacement: step 2, image 3 of 3
      • Using the spudger, create a small opening to be used to open the back case.
      • While holding the case open, insert the plastic opening tool to get a larger opening.
      • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
      Ask FixBot
    3. Visual Land Prestige 10 Front Facing Camera Replacement: step 3, image 1 of 3 Visual Land Prestige 10 Front Facing Camera Replacement: step 3, image 2 of 3 Visual Land Prestige 10 Front Facing Camera Replacement: step 3, image 3 of 3
      • now that the case is open, carefully remove the speakers and set aside.
      Ask FixBot
    4. Visual Land Prestige 10 Front Facing Camera Replacement: step 4, image 1 of 2 Visual Land Prestige 10 Front Facing Camera Replacement: step 4, image 2 of 2
      Buy
      • Gently remove the speakers from the back case with tweezers and set the case aside.
      Ask FixBot
    1. Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 1 of 3 Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 2 of 3 Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 3 of 3
      • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
      • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
      • Gently grip and pull up the front camera, covered by protective adhesive foam.
      • Set aside the Camera housing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 515
