Up to 20% off select tools
Visual Land Prestige 10 Back Case Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
82
All Time:
2,066
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Visual Land Prestige 10 Back Case Replacement, Back Case: step 1, image 1 of 3 Visual Land Prestige 10 Back Case Replacement, Back Case: step 1, image 2 of 3 Visual Land Prestige 10 Back Case Replacement, Back Case: step 1, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
      • All screws throughout this guide are the same 3mm size.
      Ask FixBot
    2. Visual Land Prestige 10 Back Case Replacement: step 2, image 1 of 3 Visual Land Prestige 10 Back Case Replacement: step 2, image 2 of 3 Visual Land Prestige 10 Back Case Replacement: step 2, image 3 of 3
      • Using the spudger, create a small opening to be used to open the back case.
      • While holding the case open, insert the plastic opening tool to get a larger opening.
      • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
      Ask FixBot
    3. Visual Land Prestige 10 Back Case Replacement: step 3, image 1 of 3 Visual Land Prestige 10 Back Case Replacement: step 3, image 2 of 3 Visual Land Prestige 10 Back Case Replacement: step 3, image 3 of 3
      • now that the case is open, carefully remove the speakers and set aside.
      Ask FixBot
    4. Visual Land Prestige 10 Back Case Replacement: step 4, image 1 of 2 Visual Land Prestige 10 Back Case Replacement: step 4, image 2 of 2
      Buy
      • Gently remove the speakers from the back case with tweezers and set the case aside.
      Ask FixBot
Author
with
Connor Reese
1,322 Reputation
6 Guides authored
1 Guide Comment
Ok but where to I go to buy the replacement for the screen? This is directing us to take apart and reassemble the tablet, but not where to buy or get a new screen.
Jordyn Glenn - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 82
All Time: 2,066
