Visioneer OneTouch 7400 USB Sensor Bar Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
79
All Time:
860
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Use this guide to remove and replace the sensor bar in the scanner bed of the Visioneer OneTouch 7400 USB.
Tools
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Outer Case: step 1, image 1 of 1
      • On the bottom of the scanner, remove the screw at the top left side.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 2, image 1 of 2 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 2, image 2 of 2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 3, image 1 of 3 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 3, image 2 of 3 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 3, image 3 of 3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 4, image 1 of 1
      • Separate the two casement pieces.
      Ask FixBot
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Belt: step 5, image 1 of 1
      • Remove the screw holding the tension spring in place.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to lift up the tension spring.
      • Be careful. The spring will fly.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 7, image 1 of 1
      • Remove the belt from the spool.
      • The spool is a loose piece; don't lose it.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 8, image 1 of 1
      • Loosen the belt enough to turn over the sensor bar.
      Ask FixBot
    5. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 9, image 1 of 2 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 9, image 2 of 2
      • With the sensor bar turned upside down, remove the screw in the middle of the bar.
      • Lift off the metal plate if it does not come away with the screw.
      Ask FixBot
    6. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 10, image 1 of 1
      • Carefully lift the belt out of the groove in the sensor bar to remove.
      Ask FixBot
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Sensor Bar: step 11, image 1 of 1
      • With the sensor bar upside down, lift the metal tab near the center.
      • Slide the metal casing on top of the sensor bar to the left to disengage it from the plastic.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 12, image 1 of 1
      • Use the spudger to pry loose the ribbon tab on the inside surface of the casement.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 13, image 1 of 1
      • Detach the ribbon from the other end and pull the plastic tab from the ribbon.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 14, image 1 of 2 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 14, image 2 of 2
      • Carefully peel the ribbon off of the casing. The ribbon is held with two-sided tape. Use the spudger to help as needed.
      • The ribbon goes under the metal bar. Gently pull the ribbon under the metal bar to remove it.
      Ask FixBot
    5. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 15, image 1 of 2 Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 15, image 2 of 2
      • Lift the sensor bar from the scanner bed.
      • To finish removing the ribbon from the sensor bar, use the spudger to pry away the clear plastic piece securing the ribbon to the bar. Detach the ribbon from the sensor bar by peeling it away from the double-sided tape.
      Ask FixBot
    6. Visioneer OneTouch 7400 USB Sensor Bar Replacement: step 16, image 1 of 1
      • Slowly pull the ribbon end straight out to remove it from the sensor bar.
      Ask FixBot
Jena
608 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 79
All Time: 860
