Visioneer OneTouch 7400 USB Motherboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
83
All Time:
849
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide shows how to remove the Visioneer OneTouch 7400 USB motherboard for repair or replacement.
WARNING: Circuitry will be exposed. Handle the motherboard carefully in order to avoid damage to the equipment and yourself. Keep the equipment away from heat sources and water.
Tools
    1. Visioneer OneTouch 7400 USB Motherboard Replacement, Outer Case: step 1, image 1 of 1
      • On the bottom of the scanner, remove the screw at the top left side.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Motherboard Replacement: step 2, image 1 of 2 Visioneer OneTouch 7400 USB Motherboard Replacement: step 2, image 2 of 2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Motherboard Replacement: step 3, image 1 of 3 Visioneer OneTouch 7400 USB Motherboard Replacement: step 3, image 2 of 3 Visioneer OneTouch 7400 USB Motherboard Replacement: step 3, image 3 of 3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Motherboard Replacement: step 4, image 1 of 1
      • Separate the two casement pieces.
      Ask FixBot
    1. Visioneer OneTouch 7400 USB Motherboard Replacement, Motherboard: step 5, image 1 of 2 Visioneer OneTouch 7400 USB Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • On the bottom half of the casing, remove the two screws in the motherboard.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Motherboard Replacement: step 6, image 1 of 1
      • Carefully detach the wires from the motherboard, pulling slowly but firmly.
      • On the right hand side, the motherboard is attached to the ribbon. Do not pull too hard.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Motherboard Replacement: step 7, image 1 of 1
      • Flip the motherboard over carefully.
      • Gently pull the ribbon out of its bed.
      Ask FixBot
Jena
608 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 83
All Time: 849
