Visioneer OneTouch 7400 USB Belt Replacement
    1. Visioneer OneTouch 7400 USB Belt Replacement, Outer Case: step 1, image 1 of 1
      • On the bottom of the scanner, remove the screw at the top left side.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Belt Replacement: step 2, image 1 of 2 Visioneer OneTouch 7400 USB Belt Replacement: step 2, image 2 of 2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Belt Replacement: step 3, image 1 of 3 Visioneer OneTouch 7400 USB Belt Replacement: step 3, image 2 of 3 Visioneer OneTouch 7400 USB Belt Replacement: step 3, image 3 of 3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Belt Replacement: step 4, image 1 of 1
      • Separate the two casement pieces.
      Ask FixBot
    1. Visioneer OneTouch 7400 USB Belt Replacement, Belt: step 5, image 1 of 1
      • Remove the screw holding the tension spring in place.
      Ask FixBot
    2. Visioneer OneTouch 7400 USB Belt Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to lift up the tension spring.
      • Be careful. The spring will fly.
      Ask FixBot
    3. Visioneer OneTouch 7400 USB Belt Replacement: step 7, image 1 of 1
      • Remove the belt from the spool.
      • The spool is a loose piece; don't lose it.
      Ask FixBot
    4. Visioneer OneTouch 7400 USB Belt Replacement: step 8, image 1 of 1
      • Loosen the belt enough to turn over the sensor bar.
      Ask FixBot
    5. Visioneer OneTouch 7400 USB Belt Replacement: step 9, image 1 of 2 Visioneer OneTouch 7400 USB Belt Replacement: step 9, image 2 of 2
      • With the sensor bar turned upside down, remove the screw in the middle of the bar.
      • Lift off the metal plate if it does not come away with the screw.
      Ask FixBot
    6. Visioneer OneTouch 7400 USB Belt Replacement: step 10, image 1 of 1
      • Carefully lift the belt out of the groove in the sensor bar to remove.
      Ask FixBot
Jena
608 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 619
