Up to 20% off select tools
Violin Strings Replacement
Views: 17K
View statistics:
Past 24 Hours:
5
Past 7 Days:
51
Past 30 Days:
242
All Time:
16,930
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide is intended to help users through the process of fixing broken or worn out violin strings. A violin has four strings: E, A, D, & G. The order of the strings from left to right is G, D, A, & E. The G string is the deepest pitched string and the E is the highest pitched string. The purpose of this guide is to enable violin players to restring their violin on their own instead of having it done at a music store.
    1. Violin Strings Replacement, Strings: step 1, image 1 of 2 Violin Strings Replacement, Strings: step 1, image 2 of 2
      • Turn the peg belonging to the string you are wanting to change to loosen the string.
      • Violins have four string. The strings from left to right go: G, D, A, & E.
      Ask FixBot
    2. Violin Strings Replacement: step 2, image 1 of 1
      • Pull the string out of the peg.
      Ask FixBot
    3. Violin Strings Replacement: step 3, image 1 of 2 Violin Strings Replacement: step 3, image 2 of 2
      • Remove the opposite end of the string from the fine tuner holder.
      Ask FixBot
    4. Violin Strings Replacement: step 4, image 1 of 2 Violin Strings Replacement: step 4, image 2 of 2
      • Place new string in peg hole.
      Ask FixBot
    5. Violin Strings Replacement: step 5, image 1 of 1
      • Turn the peg to tighten the string.
      Ask FixBot
    6. Violin Strings Replacement: step 6, image 1 of 2 Violin Strings Replacement: step 6, image 2 of 2
      • Place nub in fine tuner holder.
      Ask FixBot
    7. Violin Strings Replacement: step 7, image 1 of 1
      • Make sure the string is sitting in the groove in the bridge.
      Ask FixBot
    8. Violin Strings Replacement: step 8, image 1 of 1
      • Gently tug on string to make sure it is secure.
      Ask FixBot
5 other people completed this guide.
Author
with
Brittany Preston
245 Reputation
1 Guide authored
1 Guide Comment
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - Reply Share
Past 24 Hours: 5
Past 7 Days: 51
Past 30 Days: 242
All Time: 16,930
