Viltrox NF-E1 Unreliable Mount Fix
  1. Viltrox NF-E1 Unreliable Mount Fix, Unreliable Mount: step 1, image 1 of 2 Viltrox NF-E1 Unreliable Mount Fix, Unreliable Mount: step 1, image 2 of 2
    • We'll first remove front Nikon lens facing plate first. Be sure to remember where the white dot is.
    • Be careful as you pull out the mounting plate and the washer behind it. Remember how it was attached.
    Ask FixBot
  2. Viltrox NF-E1 Unreliable Mount Fix: step 2, image 1 of 2 Viltrox NF-E1 Unreliable Mount Fix: step 2, image 2 of 2
    • Unscrew the black screws behind the mounting plate and the washer.
    • You'll also need to unscrew the bottom plate to release the black ring.
    Ask FixBot
  3. Viltrox NF-E1 Unreliable Mount Fix: step 3, image 1 of 1
    • Sorry I missed some photo here but after you remove the black plate, you'll be able to pop out the mount lever and see the little flap where the tip of the screw driver in the photo is indicating. Add layers of tape to the lever where that will be contacting the flap.
    • It appears that the flap triggers "lock" position to the tiny PCB it is connected to. Making this flap more with thicker side of the lever seem to make it more reliable.
    • The mounting lever has spring in it. It may pop out so be careful not to lose it! Take out the black plate slowly.
    Ask FixBot
    • Now reverse the steps you took and hopefully the mount will have better contact!
    Ask FixBot
  4. Viltrox NF-E1 Unreliable Mount Fix: step 5, image 1 of 2 Viltrox NF-E1 Unreliable Mount Fix: step 5, image 2 of 2
    • Take note of how the inner washer looks like. Bump on three sides will face inward. Also note where the mounting lever stick is "poking" through.
    Ask FixBot
fyun89
121 Reputation
1 Guide authored
3 Guide Comments
Also, for anyone having trouble updating the mount with the firmware in Viltrox's website, reach out to their support and they'll give you a different firmware. I'll try to post it here as well. (NOTE: it seems some folks were able to update their firmware so there may be different versions of the mount and this may or may not work. This method worked for me, however).
fyun89 - Reply Share
please, share the firmware with us in a link
Moema Costa - Reply Share
Hi, can you share me the firmware please
fernando - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 873
