Viewsonic gTablet UPC300-2.2 Battery Replacement
  1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: step 1, image 1 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: step 1, image 2 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover.
    • Have patience! These are held in with glue and can take time and a few attempts to remove.
    • Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
  2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: step 2, image 1 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: step 2, image 2 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: step 2, image 3 of 3
    • Using the flat end of your prying tool, work the back cover away from the rest of the gTabet.
    • Starting near the charging port, work in one direction around the perimeter of the device.
    • Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Lift off back cover to reveal the interior of the device.
  3. Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: step 3, image 1 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: step 3, image 2 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: step 3, image 3 of 3
    • The battery is the large black square that dominates much of the device interior.
    • There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
  4. Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: step 4, image 1 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: step 4, image 2 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: step 4, image 3 of 3
    • Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place.
    • The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
  5. Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: step 5, image 1 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: step 5, image 2 of 3 Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: step 5, image 3 of 3
    • Using tweezers, remove the protective foam backing arch from the front-facing camera.
    • Pull the camera out of its housing and move it aside.
    • Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Gently lift the battery up and away from the rest of the device and set it aside.
2 other people completed this guide.
Cristian
591 Reputation
5 Guides authored
UMass Dartmouth, Team 4-1, Miles Fall 2014 Member of UMass Dartmouth, Team 4-1, Miles Fall 2014
UMASSD-MILES-F14S4G1
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 21
All Time: 1,816
