Community-Contributed Guide
Introduction
Go to step 1 ↓The Duomatik Control Unit/HMI is equipped with a built-in industrial-grade 3.6V 2400mAh AA (Mignon) Lithium (LiSOCl2) Battery, used for maintaining clock functionality and preserving timer settings during boiler shutdowns or power outages. Although these robust cells typically offer prolonged lifespan, eventual failure is inevitable.
Should your boiler frequently lose time and settings, it might signal the need for a battery replacement.
This in guide we will walk you through the process of replacing the battery.
Note
If you're replacing the battery as a preventive measure, when you power on the module after the repair, it might initially seem broken to you. The module will enter an error mode due to time loss, locking all functions except for setting the time. Therefore, your first step would be setting the clock before accessing other features.
Parts
3.6V 2400mAh AA Lithium Battery (Axial Pin) Available for sale on rs-online US
The original battery uses Radial Pins, but these seem to be rather rare these days.
Tools
Spudger4.9
Tool used on this step:Spudger$3.99
Insert a flathead screwdriver or a Spudger into the small notch on top of the module to gently loosen it.
Place the module on its front.
The back of the module is held in by four clips. Use Spudgers to hold the clips open while you remove the back.
Place the module on its back.
Open the flap that covers the buttons for setting the timer.
Remove the encoder knob by pulling it off.
Release the first two clips holding the PCB inside the housing.
Release the last two clips holding the PCB inside the housing.
Remove the PCB from the housing.
Desolder the negative connection.
Desolder the positive connection.
2 other people completed this guide.
5 Guide Comments
I am in this boat. Replacing the battery is not a problem. The problem is what is the procedure to reinitialise the control unit afterwards? What values need to be put back and what button presses achieve that?
The module will enter an error mode due to time loss, locking all functions except for setting the time. Therefore, your first step would be setting the time before accessing other features. I'm not sure for the process, it has been a while for me. You can just download the user manual on the Viessmann Website, though.
Thanks Sebastian, I can see the clock can be adjusted. At the moment, with the old battery still installed (I did measure it and it seemed ok to me @4.2V but will accept it may be borderline) I can adjust the time but that is all, the temperatures from the thermistors are not there, this is why I believe it may need initialising. I can also enter the options pages where you can set various options like room thermostat fitted or not and hot water cylinder temperature 60 or 70 degrees and I believe there will be a 'secret' code in there somewhere to initialise the control board. It isn't in the manual, at least, not the manual for mere users, it will be a reserved engineering code.
Maybe post your problem in the Answers forum. There are a lot of talented people on there who might be able to help you with your problem.
Already done Sebastian, thanks.
