Up to 20% off select tools
Vicks FilterFree Plus Tank Cap Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
104
All Time:
1,669
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
The Vicks FilterFree Plus is a handy device for humidifying air, but it may be necessary to replace the reservoir cap if it becomes damaged or worn. Replacing the cap is a simple process that requires just a few steps. Before starting, it is important to make sure that the device is completely free of water to avoid spills during replacement. In the following guide, we will outline the steps needed to remove and replace the Vicks FilterFree Plus reservoir cap. Be sure to follow each step carefully to ensure proper execution and operation of the device.
    1. Vicks FilterFree Plus Tank Cap Replacement, Tank Cap: step 1, image 1 of 1
      • Ensure the device is clear of water before disassembling.
      • Orient the device so the nozzle is facing the ceiling.
      • Twist off the primary water holding cap.
      Ask FixBot
    2. Vicks FilterFree Plus Tank Cap Replacement: step 2, image 1 of 2 Vicks FilterFree Plus Tank Cap Replacement: step 2, image 2 of 2
      • Place the device upside down so that the tank cap is facing you.
      • Use your hands to twist the tank cap and remove it from the device.
      Ask FixBot
Author
with
NathanBatista021
497 Reputation
4 Guides authored
1 Guide Comment
That's fine, but WHERE DO YOU GET THE TANK CAPS?????
Bonnie Warford - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 104
All Time: 1,669
