Vertical Blind Slat Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
21
Past 7 Days:
126
Past 30 Days:
421
All Time:
2,352
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you the steps of how to replace the slats of a vertical blind. The frequent use of a vertical blind can cause the slats to be loose or dirty. To help you avoid the cost of hiring a professional, this guide will show you the details of how to easily replace them. Note that if your clips of blinds are old or rusty, it may be difficult to remove, and you may need to apply a bit more force. Also, check If there is a decorative valance on the blind. If your blind has a decorative valance, carefully remove it by unclipping or unscrewing it from headrail.
The following link could be a reference of the process: https://www.youtube.com/watch?v=OmvrjysG...
Timestamps: 4:41 - 5:58
    1. Vertical Blind Slat Replacement, Slat: step 1, image 1 of 2 Vertical Blind Slat Replacement, Slat: step 1, image 2 of 2
      • Remove the old slat by lifting it upwards.
      Ask FixBot
    2. Vertical Blind Slat Replacement: step 2, image 1 of 2 Vertical Blind Slat Replacement: step 2, image 2 of 2
      • Once lifted, gently pull the slat toward you to remove it completely from the clip.
      Ask FixBot
    3. Vertical Blind Slat Replacement: step 3, image 1 of 1
      • Adjust and ensure the curve of the new slat is facing the same direction as the other old slats.
      Ask FixBot
    4. Vertical Blind Slat Replacement: step 4, image 1 of 1
      • Slide the new slat upwards into the first clip.
      Ask FixBot
    5. Vertical Blind Slat Replacement: step 5, image 1 of 1
      • Continue sliding the slat upwards until it clicks into place in the second clip.
      Ask FixBot
    6. Vertical Blind Slat Replacement: step 6, image 1 of 1
      • Once finished, gently pull the slat toward you to ensure it is securely attached.
      Ask FixBot
Finish Line
KA YEE LUI
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 126
Past 30 Days: 421
All Time: 2,352
