Verizon Ellipsis Jetpack MHS800L Screen Replacement
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: step 1, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: step 1, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: step 1, image 3 of 3
      • Remove the SIM card, that is located on top of the Jetpack.
      Ask FixBot
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 2, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 2, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 2, image 3 of 3
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
      • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
      • You may need to peel back a piece of double sided tape covering the screw hole.
      Ask FixBot
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 3, image 1 of 1
      • Remove three 1.25 mm screws.
      Ask FixBot
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 4, image 1 of 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      Ask FixBot
    5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 5, image 1 of 1
      • Once the cover is off, this is what your device will look like.
      Ask FixBot
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: step 6, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: step 6, image 2 of 2
      • Once you have the case off of your device gently pull your battery away from the device.
      • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
      Ask FixBot
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 7, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 7, image 2 of 2
      Buy
      • With a pair of Tweezers remove the yellow tape covering the battery wires.
      Ask FixBot
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 8, image 1 of 1
      Buy
      • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
      • Do not squeeze the wires to hard you may damage them and cause a short.
      Ask FixBot
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 9, image 1 of 1
      • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
      Ask FixBot
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: step 10, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: step 10, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: step 10, image 3 of 3
      • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
      Ask FixBot
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 11, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 11, image 2 of 2
      Buy
      • Using the Tweezers gently coax the display data cable out of circuit board connector.
      • Do not squeeze the display data cable to hard you may damage it and cause a short.
      Ask FixBot
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 12, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: step 12, image 2 of 2
      Buy
      • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
      Ask FixBot
Richard J Porras
504 Reputation
3 Guides authored
IUPUI, Team 3-3, Baechle Spring 2016 Member of IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 2,523
