Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement
  1. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: step 1, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: step 1, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement, Plastic Case: step 1, image 3 of 3
    • Remove the SIM card, that is located on top of the Jetpack.
    Ask FixBot
  2. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 2, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 2, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 2, image 3 of 3
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
    Ask FixBot
  3. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 3, image 1 of 1
    • Remove three 1.25 mm screws.
    Ask FixBot
  4. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 4, image 1 of 1
    iFixit Opening Picks (Set of 6)
    $4.95
    Buy
    Ask FixBot
  5. Verizon Ellipsis Jetpack MHS800L Plastic Case Replacement: step 5, image 1 of 1
    • Once the cover is off, this is what your device will look like.
    Ask FixBot
2 other people completed this guide.
Richard J Porras
504 Reputation
3 Guides authored
IUPUI, Team 3-3, Baechle Spring 2016 Member of IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 816
