Verizon Ellipsis Jetpack MHS800L Battery Replacement
  1. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: step 1, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: step 1, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Plastic Case: step 1, image 3 of 3
    • Remove the SIM card, that is located on top of the Jetpack.
    Ask FixBot
  2. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 2, image 1 of 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 2, image 2 of 3 Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 2, image 3 of 3
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
    Ask FixBot
  3. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 3, image 1 of 1
    • Remove three 1.25 mm screws.
    Ask FixBot
  4. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 4, image 1 of 1
    iFixit Opening Picks (Set of 6)
    $4.95
    Buy
    Ask FixBot
  5. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 5, image 1 of 1
    • Once the cover is off, this is what your device will look like.
    Ask FixBot
  6. Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: step 6, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Battery Replacement, Battery: step 6, image 2 of 2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
    Ask FixBot
  7. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 7, image 1 of 2 Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 7, image 2 of 2
    Buy
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
    Ask FixBot
  8. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 8, image 1 of 1
    Buy
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
    Ask FixBot
  9. Verizon Ellipsis Jetpack MHS800L Battery Replacement: step 9, image 1 of 1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
    Ask FixBot
6 other people completed this guide.
Richard J Porras
504 Reputation
3 Guides authored
IUPUI, Team 3-3, Baechle Spring 2016 Member of IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Members
6 Guides authored
5 Guide Comments
I'd like to let you know that after step 9, it is possible to unwrap the battery and break loose the circuit board on the battery. At which point you can reinstall the circuit board in the router with no battery attached. This makes the Jetpack plug-in only which is all I need it for anyways. It was a great and free fix for my swollen battery.
Thanks for the article!
Jeff Lovett - Reply Share
Opps, I think that steps 3 & 4 have been reversed. You can't get to the "3 additional screws" until you're looking at the red cover which is below the black cover that needs to be pried off first.
Otherwise, the process seems to be going well.
bevrievley - Reply Share
It’s unclear. Once you unscrew that first screw, you have to remove the TOP black portion (the picture looks like you’re removing the bottom). Once you remove that top portion, the red plastic is exposed, revealing the three other screws.
imsonnyburnett - Reply Share
And -- continuing with step 5, there are some plastic "snap" locks between the red and black covers -- 5 by my count, 2 along each of the long edges, 1 along the charging port edge. Always good to pry carefully.
Once apart, battery is on bottom and can be easily removed/replaced as per steps 7 & 8.
now how do we FORCE a factory data reset without the admin password?
baily jacoby - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 25
All Time: 8,179
