Up to 20% off select tools
Verizon Ellipsis 7 Power Button Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
92
All Time:
2,796
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace a defective power button on the Verizon Ellipsis 7.
    1. Verizon Ellipsis 7 Power Button Replacement, Power Button: step 1, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement, Power Button: step 1, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Power down device by holding down the power button until the screen goes black.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in, then remove after it pops out with an audible click.
      Ask FixBot
    2. Verizon Ellipsis 7 Power Button Replacement: step 2, image 1 of 2 Verizon Ellipsis 7 Power Button Replacement: step 2, image 2 of 2
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      Ask FixBot
    3. Verizon Ellipsis 7 Power Button Replacement: step 3, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement: step 3, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      Ask FixBot
    4. Verizon Ellipsis 7 Power Button Replacement: step 4, image 1 of 2 Verizon Ellipsis 7 Power Button Replacement: step 4, image 2 of 2
      • Disconnect speakers from motherboard.
      • Use the tweezers to carefully disconnect speakers from motherboard.
      Ask FixBot
    5. Verizon Ellipsis 7 Power Button Replacement: step 5, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement: step 5, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement: step 5, image 3 of 3
      • Disconnect the battery.
      • Use tweezers to carefully disengage connector.
      Ask FixBot
    6. Verizon Ellipsis 7 Power Button Replacement: step 6, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement: step 6, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement: step 6, image 3 of 3
      • Disconnect the digitizer ribbon cable.
      • Use a nylon spudger to lift back tab.
      • After the back tab has been lifted the cable can be removed with tweezers.
      • When using tweezers, be careful not to damage the ribbon cable.
      Ask FixBot
    7. Verizon Ellipsis 7 Power Button Replacement: step 7, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement: step 7, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement: step 7, image 3 of 3
      • Disconnect the ribbon cable.
      • Use a nylon spudger to lift tab.
      • After the tab is lifted, the cable can be removed.
      Ask FixBot
    8. Verizon Ellipsis 7 Power Button Replacement: step 8, image 1 of 3 Verizon Ellipsis 7 Power Button Replacement: step 8, image 2 of 3 Verizon Ellipsis 7 Power Button Replacement: step 8, image 3 of 3
      • Disconnect all antenna cables.
      • Use a nylon spudger to pop the antenna cable from the base.
      Ask FixBot
    9. Verizon Ellipsis 7 Power Button Replacement: step 9, image 1 of 2 Verizon Ellipsis 7 Power Button Replacement: step 9, image 2 of 2
      • Remove 9 Phillips #00 screws. The length of 4.76 mm
      • There is 1 Phillips #00 screw that is 3.175mm in length. This screw also has a larger head then the rest of the screws.
      • Note: when reassembling the motherboard, screw the bigger headed screw in the original location.
      Ask FixBot
    10. Verizon Ellipsis 7 Power Button Replacement: step 10, image 1 of 2 Verizon Ellipsis 7 Power Button Replacement: step 10, image 2 of 2
      • Remove the motherboard.
      • Locate power button.
      Ask FixBot
    11. Verizon Ellipsis 7 Power Button Replacement: step 11, image 1 of 2 Verizon Ellipsis 7 Power Button Replacement: step 11, image 2 of 2
      • Desolder the power button from the motherboard.
      • Learn how to solder and desolder components here!
      Ask FixBot
2 other people completed this guide.
Author
with
Taylor Nieman
275 Reputation
1 Guide authored
2 Guide Comments
I dropped mine and the button is broke. It looks like I should be able to just pop it back, but it's not reaching the button in the tablet. Do I really have to order this just for it to turn on? I mean, I use a paper clip, but I use this for Uber and it's not safe when I'm driving, lol.
tklahn79 - Reply Share
I have looked everywhere for replacement buttons. Any help you can give in finding the parts is appreciated.
Regina Cain - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 92
All Time: 2,796
