Verizon Ellipsis 7 Front Facing Camera Replacement
    1. Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: step 1, image 1 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: step 1, image 2 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: step 1, image 3 of 3
      • Hold down the power button until the screen goes black to turn off the device.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in and pull it out after hearing a click.
      Ask FixBot
    2. Verizon Ellipsis 7 Front Facing Camera Replacement: step 2, image 1 of 2 Verizon Ellipsis 7 Front Facing Camera Replacement: step 2, image 2 of 2
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      Ask FixBot
    3. Verizon Ellipsis 7 Front Facing Camera Replacement: step 3, image 1 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 3, image 2 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the charging (micro-USB) port.
      • Unscrew the indicated screws using the Phillips #00 screwdriver.
      • The screws shown in the picture are the more common 4.76 mm.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      Ask FixBot
    4. Verizon Ellipsis 7 Front Facing Camera Replacement: step 4, image 1 of 2 Verizon Ellipsis 7 Front Facing Camera Replacement: step 4, image 2 of 2
      • Remove the charging port board from the phone using tweezers.
      • Place the replacement charging port into the phone.
      • Be cautious when replacing the ribbon cable onto the new charging port board.
      Ask FixBot
    1. Verizon Ellipsis 7 Front Facing Camera Replacement, Speaker: step 5, image 1 of 2 Verizon Ellipsis 7 Front Facing Camera Replacement, Speaker: step 5, image 2 of 2
      • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
      Ask FixBot
    2. Verizon Ellipsis 7 Front Facing Camera Replacement: step 6, image 1 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 6, image 2 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 6, image 3 of 3
      Buy
      • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
      • Using tweezers carefully pull the speakers up and out of device.
      Ask FixBot
    1. Verizon Ellipsis 7 Front Facing Camera Replacement, Front Facing Camera: step 7, image 1 of 1
      Buy
      • Use tweezers to carefully disconnect the power cable bundle from the motherboard.
      Ask FixBot
    2. Verizon Ellipsis 7 Front Facing Camera Replacement: step 8, image 1 of 2 Verizon Ellipsis 7 Front Facing Camera Replacement: step 8, image 2 of 2
      • Remove the 10 screws from the motherboard using a Phillips #0 screwdriver.
      • The screws shown in the first picture is the more common 4.76 mm.
      • The screw shown in the second picture is shorter than the rest of the screws: 3.175 mm.
      Ask FixBot
    3. Verizon Ellipsis 7 Front Facing Camera Replacement: step 9, image 1 of 2 Verizon Ellipsis 7 Front Facing Camera Replacement: step 9, image 2 of 2
      • Using a spudger, remove the 5 antenna cable connectors from the motherboard.
      Ask FixBot
    4. Verizon Ellipsis 7 Front Facing Camera Replacement: step 10, image 1 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 10, image 2 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 10, image 3 of 3
      • Disconnect the two ZIF connectors that are connected to the motherboard with the spudger. Lift up the metal part of the connector and pull it off of its port
      • Once disconnected from the port, pull the metal part away from its connector carefully with the tweezers.
      • When all the connectors have been disconnected, you can gently lift the motherboard from the device.
      Ask FixBot
    5. Verizon Ellipsis 7 Front Facing Camera Replacement: step 11, image 1 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 11, image 2 of 3 Verizon Ellipsis 7 Front Facing Camera Replacement: step 11, image 3 of 3
      • Make sure the press lift connector is disconnected using the spudger, then carefully flip the motherboard over.
      • Disconnect the camera in the middle of the board using tweezers.
      Ask FixBot
Anthony Arredondo
412 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 859
