Verizon Ellipsis 7 Battery Replacement
    1. Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 1 of 3 Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 2 of 3 Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 3 of 3
      • Power down device by holding down the power button until the screen goes black.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in and then pull out after hearing a click.
      Ask FixBot
    2. Verizon Ellipsis 7 Battery Replacement: step 2, image 1 of 2 Verizon Ellipsis 7 Battery Replacement: step 2, image 2 of 2
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      Ask FixBot
    3. Verizon Ellipsis 7 Battery Replacement: step 3, image 1 of 3 Verizon Ellipsis 7 Battery Replacement: step 3, image 2 of 3 Verizon Ellipsis 7 Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      Ask FixBot
11 other people completed this guide.
Scott Mangin
609 Reputation
2 Guides authored
Cal Poly, Team 13-5, Banghart Winter 2017 Member of Cal Poly, Team 13-5, Banghart Winter 2017
CPSU-BANGHART-W17S13G5
4 Members
24 Guides authored
8 Guide Comments
so much for the charging port. You didn’t mention the battery. ?
good1946scout - Reply Share
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - Reply Share
First time on Ifixit and they leave me two steps from the goal; not much of a confidence-builder for this site!
Groove - Reply Share
WTH? Replacing the battery?
kaycha12 - Reply Share
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
Kermit Allison - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 45
All Time: 30,673
