Verizon Ellipsis 10 Speaker Replacement
    1. Verizon Ellipsis 10 Speaker Replacement, Back Cover: step 1, image 1 of 1
      • Open the SD/SIM card cover to start prying off the back cover.
      Ask FixBot
    2. Verizon Ellipsis 10 Speaker Replacement: step 2, image 1 of 1
      • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
      Ask FixBot
    3. Verizon Ellipsis 10 Speaker Replacement: step 3, image 1 of 1
      • Follow along the edge of the device to undo all of the retaining clips.
      Ask FixBot
    4. Verizon Ellipsis 10 Speaker Replacement: step 4, image 1 of 1
      • Once all the clips are undone, the back panel should come off with little effort.
      Ask FixBot
    1. Verizon Ellipsis 10 Speaker Replacement, Battery: step 5, image 1 of 1
      • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
      Ask FixBot
    2. Verizon Ellipsis 10 Speaker Replacement: step 6, image 1 of 1
      • Remove the top piece of tape using an iFixit opening tool.
      Ask FixBot
    3. Verizon Ellipsis 10 Speaker Replacement: step 7, image 1 of 1
      • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
      Ask FixBot
    4. Verizon Ellipsis 10 Speaker Replacement: step 8, image 1 of 1
      • Unplug the battery power connector by sliding the white plastic plug down away from the board.
      Ask FixBot
    5. Verizon Ellipsis 10 Speaker Replacement: step 9, image 1 of 1
      • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
      Ask FixBot
    1. Verizon Ellipsis 10 Speaker Replacement, Speaker: step 10, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four M1.5 screws from the right speaker.
      Ask FixBot
    2. Verizon Ellipsis 10 Speaker Replacement: step 11, image 1 of 1
      • Remove the black and white wires connected to the motherboard by pulling up on their connections.
      • Remove the three strips of tape.
      Ask FixBot
    3. Verizon Ellipsis 10 Speaker Replacement: step 12, image 1 of 1
      • Remove the four M1.5 screws on the left speaker.
      • Remove the speakers from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 35
All Time: 398
