Up to 20% off select tools
Verizon Ellipsis 10 Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
52
All Time:
490
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide is designed to provide you with simple steps to remove and replace the Verizon Ellipsis 10 Camera.
    1. Verizon Ellipsis 10 Camera Replacement, Back Cover: step 1, image 1 of 1
      • Open the SD/SIM card cover to start prying off the back cover.
      Ask FixBot
    2. Verizon Ellipsis 10 Camera Replacement: step 2, image 1 of 1
      • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
      Ask FixBot
    3. Verizon Ellipsis 10 Camera Replacement: step 3, image 1 of 1
      • Follow along the edge of the device to undo all of the retaining clips.
      Ask FixBot
    4. Verizon Ellipsis 10 Camera Replacement: step 4, image 1 of 1
      • Once all the clips are undone, the back panel should come off with little effort.
      Ask FixBot
    1. Verizon Ellipsis 10 Camera Replacement, Battery: step 5, image 1 of 1
      • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
      Ask FixBot
    2. Verizon Ellipsis 10 Camera Replacement: step 6, image 1 of 1
      • Remove the top piece of tape using an iFixit opening tool.
      Ask FixBot
    3. Verizon Ellipsis 10 Camera Replacement: step 7, image 1 of 1
      • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
      Ask FixBot
    4. Verizon Ellipsis 10 Camera Replacement: step 8, image 1 of 1
      • Unplug the battery power connector by sliding the white plastic plug down away from the board.
      Ask FixBot
    5. Verizon Ellipsis 10 Camera Replacement: step 9, image 1 of 1
      • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
      Ask FixBot
    1. Verizon Ellipsis 10 Camera Replacement, Camera: step 10, image 1 of 1
      • Remove 4 M1.5 screws holding in the labeled LTE module.
      Ask FixBot
    2. Verizon Ellipsis 10 Camera Replacement: step 11, image 1 of 1
      • Use a nylon spudger to pry up the module.
      • It's held in with some clips so there will be a little bit of resistance.
      Ask FixBot
    3. Verizon Ellipsis 10 Camera Replacement: step 12, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 12, image 2 of 2
      • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
      • The module should come up with a little resistance.
      Ask FixBot
    4. Verizon Ellipsis 10 Camera Replacement: step 13, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up the front camera off its locating post.
      Ask FixBot
    5. Verizon Ellipsis 10 Camera Replacement: step 14, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 14, image 2 of 2
      • Remove the non-conductive tape covering the camera ribbon cable.
      • You may need to remove the white antenna cable to remove the tape.
      Ask FixBot
    6. Verizon Ellipsis 10 Camera Replacement: step 15, image 1 of 1
      • Carefully unplug the ribbon cable from the motherboard.
      Ask FixBot
    7. Verizon Ellipsis 10 Camera Replacement: step 16, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 16, image 2 of 2
      • Peel up the ribbon cable carefully as it is glued to the device.
      • After having peeled up the cable, the cameras should be free to come out of the device.
      Ask FixBot
Author
with
Mary Duran
606 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 490
