Up to 20% off select tools
Vent Panel Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
68
All Time:
620
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Vent Panel Disassembly, Remove Service Panel Screws: step 1, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      Ask FixBot
    2. Vent Panel Disassembly, Dislodge Service Panel: step 2, image 1 of 3 Vent Panel Disassembly, Dislodge Service Panel: step 2, image 2 of 3 Vent Panel Disassembly, Dislodge Service Panel: step 2, image 3 of 3
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      Ask FixBot
    1. Vent Panel Disassembly, Remove screw covers: step 3, image 1 of 1
      • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
      Ask FixBot
    2. Vent Panel Disassembly, Unfasten vent panel: step 4, image 1 of 2 Vent Panel Disassembly, Unfasten vent panel: step 4, image 2 of 2
      • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
      • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
      Ask FixBot
    3. Vent Panel Disassembly, Remove vent panel: step 5, image 1 of 2 Vent Panel Disassembly, Remove vent panel: step 5, image 2 of 2
      • Remove the vent panel by lifting directly up to dislodge it from the brace.
      Ask FixBot
Author
with
iodyne
462 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 620
