Velocity NoteMagix M10 A82 Hard Drive Replacement
    1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: step 1, image 1 of 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Place the notebook on the table, with the battery facing away from you.
      • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
      • Maintain holding the right switch in the "unlock" position.
      • Use your left hand to slide the left switch from "lock" to "unlock".
      Ask FixBot
    2. Velocity NoteMagix M10 A82 Hard Drive Replacement: step 2, image 1 of 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: step 2, image 2 of 2
      • Maintain both left and right switches in the "unlock" position.
      • Use your forefingers to push the battery out of the computer.
      Ask FixBot
    1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
      Ask FixBot
    2. Velocity NoteMagix M10 A82 Hard Drive Replacement: step 4, image 1 of 1
      • Lift the HDD plate off of the back to reveal the hard drive.
      Ask FixBot
    3. Velocity NoteMagix M10 A82 Hard Drive Replacement: step 5, image 1 of 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: step 5, image 2 of 2
      • Use the spudger to push the area above the connector on the hard drive to the right.
      • Lift the hard drive gently from the computer with the spudger.
      Ask FixBot
Sam Middleton
401 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Fall 2013 Member of Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 603
