Velocity Micro Cruz T301 Motherboard Replacement
    1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: step 1, image 1 of 1
      • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
      Ask FixBot
    2. Velocity Micro Cruz T301 Motherboard  Replacement: step 2, image 1 of 1
      • Insert a small opening tool between the rear panel and the tablet.
      Ask FixBot
    3. Velocity Micro Cruz T301 Motherboard  Replacement: step 3, image 1 of 1
      • The large opening tool is not needed any more.
      Ask FixBot
    4. Velocity Micro Cruz T301 Motherboard  Replacement: step 4, image 1 of 2 Velocity Micro Cruz T301 Motherboard  Replacement: step 4, image 2 of 2
      • Move the small tool opener around the rear panel to free the 12 edges.
      Ask FixBot
    5. Velocity Micro Cruz T301 Motherboard  Replacement: step 5, image 1 of 1
      • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
      Ask FixBot
    6. Velocity Micro Cruz T301 Motherboard  Replacement: step 6, image 1 of 1
      • Using a plastic Spudger remove the battery connector.
      Ask FixBot
    7. Velocity Micro Cruz T301 Motherboard  Replacement: step 7, image 1 of 1
      • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
      Ask FixBot
    8. Velocity Micro Cruz T301 Motherboard  Replacement: step 8, image 1 of 1
      • Place a metal Spudger between the tablet and the back cover.
      Ask FixBot
    9. Velocity Micro Cruz T301 Motherboard  Replacement: step 9, image 1 of 1
      • Move the spudger around the tablet to release the clips attached to the tablet.
      Ask FixBot
    10. Velocity Micro Cruz T301 Motherboard  Replacement: step 10, image 1 of 1
      • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
      Ask FixBot
    11. Velocity Micro Cruz T301 Motherboard  Replacement: step 11, image 1 of 1
      • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
      • Use a nylon spudger to remove the top plug connector from the motherboard.
      Ask FixBot
    12. Velocity Micro Cruz T301 Motherboard  Replacement: step 12, image 1 of 2 Velocity Micro Cruz T301 Motherboard  Replacement: step 12, image 2 of 2
      • Use a metal spudger to remove both screen cable connectors
      Ask FixBot
    13. Velocity Micro Cruz T301 Motherboard  Replacement: step 13, image 1 of 1
      • use openning tools to remove the motherboard.
      Ask FixBot
Ahmed
227 Reputation
1 Guide authored
USF Tampa, Team 1-6, Cagle Fall 2016 Member of USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 386
