Velocity Micro Cruz Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
72
All Time:
523
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
The Velocity Micro Cruz is fairly simple to work on. Please make sure that you are mindful of where you are placing the individual screws. The screws and their location are important when reassembling the tablet.
Tools
    1. Velocity Micro Cruz Speaker Replacement, Remove the Back: step 1, image 1 of 1
      • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
      • Gently work the tool around the diameter of the tablet until the back pops completely off.
      Ask FixBot
    2. Velocity Micro Cruz Speaker Replacement, Remove All Screws: step 2, image 1 of 2 Velocity Micro Cruz Speaker Replacement, Remove All Screws: step 2, image 2 of 2
      • Use the screwdrivers to remove all the screws.
      • Ensure that all screws are removed before moving on to the next step.
      Ask FixBot
    3. Velocity Micro Cruz Speaker Replacement, Remove LCD Connector: step 3, image 1 of 1
      • Remove the bottom LCD connector by gently pulling it away from the motherboard.
      Ask FixBot
    4. Velocity Micro Cruz Speaker Replacement, Separate the Frame from the Housing: step 4, image 1 of 1
      • Identify the speaker wires.
      • Use a plastic opening tool to gently pry underneath the frame of the grey plastic frame until it completely separates from the housing.
      Ask FixBot
    5. Velocity Micro Cruz Speaker Replacement, Remove and Replace the Speaker: step 5, image 1 of 1
      • Use the wire cutters to clip the speaker wires in the middle
      • Use a plastic opening tool to remove the speaker.
      • Insert the new speaker in its place and solder the old and new wires together.
      • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
      Ask FixBot
T Smith
205 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 72
All Time: 523
