This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Velleman DVM020 Multimeter Protective Case Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
64
All Time:
180
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide explains how to remove and replace the protective case on your Velleman DVM020 multimeter.
The case protects the multimeter from drops and impacts.
It must be removed to replace the batteries or the fuses.
    1. Velleman DVM020 Multimeter Protective Case Replacement, Turn off the multimeter: step 1, image 1 of 2 Velleman DVM020 Multimeter Protective Case Replacement, Turn off the multimeter: step 1, image 2 of 2
      • Turn off your multimeter.
      • Unplug the test leads from the measurement jacks of your multimeter.
      Ask FixBot
    2. Velleman DVM020 Multimeter Protective Case Replacement, Release the edges: step 2, image 1 of 2 Velleman DVM020 Multimeter Protective Case Replacement, Release the edges: step 2, image 2 of 2
      • Release the edge from the top-left corner.
      • Release the edge from the top-right corner.
      Ask FixBot
    3. Velleman DVM020 Multimeter Protective Case Replacement, Remove the multimeter: step 3, image 1 of 3 Velleman DVM020 Multimeter Protective Case Replacement, Remove the multimeter: step 3, image 2 of 3 Velleman DVM020 Multimeter Protective Case Replacement, Remove the multimeter: step 3, image 3 of 3
      • Press the case to pop the top of the multimeter out.
      • Remove the multimeter.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Coco
495 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 64
All Time: 180
