This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Velleman DVM020 Multimeter Fuse Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
75
All Time:
1,127
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a step-by-step guide to replace the fuses of a Velleman DVM020 multimeter.
This multimeter includes two fuses with the following specifications:
  • 10 A - 600 V: protects the high current measurement function
  • 200 mA - 600 V: protects most of the multimeter's functions
If your multimeter stops measuring current in the 10 A mode, the 10 A fuse likely needs to be replaced with the following:
  • 5 x 20 mm 10 A - 600 V ceramic fuse
If your multimeter stops measuring voltage, resistance, or current, the 200 mA fuse is likely blown. It must be replaced with the following fuse:
  • 5 x 20 mm 200 mA - 600 V ceramic fuse
Do not install fuses with higher amperage or voltage ratings than the specifications, as this could damage your multimeter. You can safely install fuses with lower current or voltage ratings; your multimeter will simply not function at full capacity.
Fuses rarely need to be replaced, and blown fuses are almost always the result of human error.
Parts
Tools
    1. Velleman DVM020 Multimeter Fuse Replacement, Turn off the multimeter: step 1, image 1 of 2 Velleman DVM020 Multimeter Fuse Replacement, Turn off the multimeter: step 1, image 2 of 2
      • Turn off your multimeter.
      • Unplug the test leads from the measurement jacks of your multimeter.
      Ask FixBot
    2. Velleman DVM020 Multimeter Fuse Replacement, Release the edges: step 2, image 1 of 2 Velleman DVM020 Multimeter Fuse Replacement, Release the edges: step 2, image 2 of 2
      • Release the edge from the top-left corner.
      • Release the edge from the top-right corner.
      Ask FixBot
    3. Velleman DVM020 Multimeter Fuse Replacement, Remove the multimeter: step 3, image 1 of 3 Velleman DVM020 Multimeter Fuse Replacement, Remove the multimeter: step 3, image 2 of 3 Velleman DVM020 Multimeter Fuse Replacement, Remove the multimeter: step 3, image 3 of 3
      • Press the case to pop the top of the multimeter out.
      • Remove the multimeter.
      Ask FixBot
    1. Velleman DVM020 Multimeter Fuse Replacement, Unscrew the housing: step 4, image 1 of 1
      • Unscrew the four screws.
      Ask FixBot
    2. Velleman DVM020 Multimeter Fuse Replacement, Opening the housing: step 5, image 1 of 2 Velleman DVM020 Multimeter Fuse Replacement, Opening the housing: step 5, image 2 of 2
      • Grasp the two halves (front and back) of the multimeter and pull to separate them.
      Ask FixBot
    3. Velleman DVM020 Multimeter Fuse Replacement, Removing the fuses: step 6, image 1 of 3 Velleman DVM020 Multimeter Fuse Replacement, Removing the fuses: step 6, image 2 of 3 Velleman DVM020 Multimeter Fuse Replacement, Removing the fuses: step 6, image 3 of 3
      • Locate the two fuses:
      • 200 mA / 600 V
      • 10 A / 600 V
      • Use a spudger or your fingers to extract the fuse from its holder.
      Ask FixBot
    4. Velleman DVM020 Multimeter Fuse Replacement, Replacing damaged fuses: step 7, image 1 of 1
      • Be sure to use the correct fuses!
      • To reinstall the fuses, you must respect their respective locations by using the markings on the circuit board as a guide:
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
3 other people completed this guide.
Coco
495 Reputation
3 Guides authored
1 Guide Comment
Fousseni kone
Fousseynou Kone - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 75
All Time: 1,127
