This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓This guide explains how to replace the batteries in a Velleman DVM020 multimeter.
You may need to replace the batteries if a battery icon appears at the top of the screen, if the display is dim, shows uneven contrast, or if the numbers do not appear correctly when powering on.
Turn off your multimeter.
Unplug the test leads from the measurement jacks of your multimeter.
Release the edge from the top-left corner.
Release the edge from the top-right corner.
Press the case to pop the top of the multimeter out.
Remove the multimeter.
Remove the batteries by pushing against the spring and pivoting them upward
To reassemble your device, follow the instructions in reverse order.
