Vauxhall Gear Shift Gaiter Replacement
  1. Vauxhall Gear Shift Gaiter Replacement, Examine existing gaiter: step 1, image 1 of 1
    • Examine existing gaiter and take note of how its installed. A quick snap with your camera phone is helpful!
    Ask FixBot
  2. Vauxhall Gear Shift Gaiter Replacement, Remove existing gaiter: step 2, image 1 of 3 Vauxhall Gear Shift Gaiter Replacement, Remove existing gaiter: step 2, image 2 of 3 Vauxhall Gear Shift Gaiter Replacement, Remove existing gaiter: step 2, image 3 of 3
    • Carefully cut through the existing cable tie or chord
    • Pull the gaiter up over the gear knob
    Ask FixBot
  3. Vauxhall Gear Shift Gaiter Replacement, Fit New Gaiter: step 3, image 1 of 3 Vauxhall Gear Shift Gaiter Replacement, Fit New Gaiter: step 3, image 2 of 3 Vauxhall Gear Shift Gaiter Replacement, Fit New Gaiter: step 3, image 3 of 3
    • Place the new gaiter over the gear knob upside down
    • Ensure the cable tip is in the correct position (usually towards the rear)
    • Locate the tie retaining groove
    • Tighten the tie securely and trim excess
    Ask FixBot
  4. Vauxhall Gear Shift Gaiter Replacement, Job Finished!: step 4, image 1 of 1
    • Enjoy your shiny new gaiter!
    • Perhaps its time to replace the handbrake one? :)
    Ask FixBot
Its quick and easy to refresh your interior by replacing a torn or worn gaiter.
5 other people completed this guide.
Andrew Armstrong
733 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 92
All Time: 3,323
