VanMoof S2 Bel and Boost Button Replacement
  1. VanMoof S2 Bel and Boost Button Replacement, Loosen the caliper: step 1, image 1 of 1
    • Brake cable needs to be loosened at caliper, undo the bolt with a 5mm allen key (you don’t have to remove the bolt).
    Ask FixBot
  2. VanMoof S2 Bel and Boost Button Replacement, Remove the brake from the lever: step 2, image 1 of 1
    • Pull the right brake lever and remove the brake wire from the lever.
    Ask FixBot
  3. VanMoof S2 Bel and Boost Button Replacement, Gain access to the cables: step 3, image 1 of 1
    • Slide the outer sleeve of the cables up to gain access to the cable.
    Ask FixBot
  4. VanMoof S2 Bel and Boost Button Replacement, Cut open the cable: step 4, image 1 of 1
    • Cut the shrink sleeve open along the length of the cable. Be careful not to cut the cables or yourself.
    Ask FixBot
  5. VanMoof S2 Bel and Boost Button Replacement, Disconnect the connectors: step 5, image 1 of 1
    • Disconnect the connectors and cut off the connectors on the bike side.
    Ask FixBot
  6. VanMoof S2 Bel and Boost Button Replacement, Strip the cables: step 6, image 1 of 1
    • Strip both cables and connect them with your fingers to check if the wiring is ok (the bike should be switching power levels while bike is on).
    Ask FixBot
  7. VanMoof S2 Bel and Boost Button Replacement, Time to solder: step 7, image 1 of 1
    • If this is working, solder the non-connector side of the extended cable to the stripped cable on the bike side (if this is not working, bike needs to be shipped to VanMoof).
    Ask FixBot
  8. VanMoof S2 Bel and Boost Button Replacement, Get the cables in the frame: step 8, image 1 of 1
    • Push the cable in the frame, try to push it down and not back (towards the display). To check if it is pushed in properly, turn the handle bar as far to the left as possible. You should feel a firm stop, compare this with the right side. If it feels soft (damped) reinsert the cable and test again.
    Ask FixBot
  9. VanMoof S2 Bel and Boost Button Replacement, Re-connect the connectors: step 9, image 1 of 1
    • Re-connect the connectors from the extended cable to the connectors on the button side again.
    Ask FixBot
  10. VanMoof S2 Bel and Boost Button Replacement, Testing the button: step 10, image 1 of 1
    • Test the button (if it switches power levels while the bike is turned on).
    Ask FixBot
  11. VanMoof S2 Bel and Boost Button Replacement, Re-attach the brake: step 11, image 1 of 1
    • If it works correctly, re-attach the brake cable.
    Ask FixBot
  12. VanMoof S2 Bel and Boost Button Replacement, Fixed!: step 12, image 1 of 1
    • Boost button is extended and fixed.
    Ask FixBot
Amani
207 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 625
