Valve Index Headset Tether and Trident Cable Replacement
  1. Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: step 1, image 1 of 2 Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: step 1, image 2 of 2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
    Ask FixBot
  2. Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: step 2, image 1 of 3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: step 2, image 2 of 3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: step 2, image 3 of 3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
    Ask FixBot
  3. Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: step 3, image 1 of 2 Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: step 3, image 2 of 2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
    Ask FixBot
  4. Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: step 4, image 1 of 2 Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: step 4, image 2 of 2
    • Pull the tether cable straight back out of the headset.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
15 other people completed this guide.
Sam Omiotek
99,427 Reputation
290 Guides authored
4 Guide Comments
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
blub blub - Reply Share
Thanks, the clip was giving me problems and this gave me the confidence that I was on the right path. :D
William Wilkins - Reply Share
Again this autor doesn't understand the meaning of replacing, he just shows us how to dismantle the headset, not how to reinstall it correctly. Useless guide...
Jason Bouchard - Reply Share
@jasonbouchard Install by following the steps in reverse....it's not rocket science
C O - Reply Share
Past 24 Hours: 24
Past 7 Days: 126
Past 30 Days: 556
All Time: 43,676
