Valve Index Headset Motherboard Replacement
    1. Valve Index Headset Motherboard Replacement, Remove the front cover: step 1, image 1 of 2 Valve Index Headset Motherboard Replacement, Remove the front cover: step 1, image 2 of 2
      • Use your hand to pull the front cover straight off of the front of the headset.
      • The front cover is held in place by four magnets that secure to screws in the motherboard cover.
      • Before installing a front cover, ensure the four screws securing the motherboard cover are installed. Otherwise, the front cover will not stay in place.
      Ask FixBot
    1. Valve Index Headset Motherboard Replacement, Remove the motherboard cover: step 2, image 1 of 1
      • Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
      Ask FixBot
    2. Valve Index Headset Motherboard Replacement: step 3, image 1 of 2 Valve Index Headset Motherboard Replacement: step 3, image 2 of 2
      • Remove the motherboard cover from the headset.
      Ask FixBot
    3. Valve Index Headset Motherboard Replacement, Remove the front fascia: step 4, image 1 of 1
      • Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
      • Four 6.3 mm screws with fine threads
      • Four 6.0 mm screws with coarse threads
      Ask FixBot
    4. Valve Index Headset Motherboard Replacement: step 5, image 1 of 3 Valve Index Headset Motherboard Replacement: step 5, image 2 of 3 Valve Index Headset Motherboard Replacement: step 5, image 3 of 3
      • Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
      • Disconnect the FPC ribbon cable from the motherboard.
      Ask FixBot
    5. Valve Index Headset Motherboard Replacement: step 6, image 1 of 3 Valve Index Headset Motherboard Replacement: step 6, image 2 of 3 Valve Index Headset Motherboard Replacement: step 6, image 3 of 3
      • Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
      • Disconnect the FPC ribbon cable.
      Ask FixBot
    6. Valve Index Headset Motherboard Replacement: step 7, image 1 of 2 Valve Index Headset Motherboard Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. Valve Index Headset Motherboard Replacement: step 8, image 1 of 2 Valve Index Headset Motherboard Replacement: step 8, image 2 of 2
      • Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
      Ask FixBot
    8. Valve Index Headset Motherboard Replacement: step 9, image 1 of 2 Valve Index Headset Motherboard Replacement: step 9, image 2 of 2
      • Insert an opening pick in between the front fascia and the headset.
      • Slide the opening pick over to separate the front fascia from the headset.
      Ask FixBot
    9. Valve Index Headset Motherboard Replacement: step 10, image 1 of 2 Valve Index Headset Motherboard Replacement: step 10, image 2 of 2
      • Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
      Ask FixBot
    10. Valve Index Headset Motherboard Replacement: step 11, image 1 of 2 Valve Index Headset Motherboard Replacement: step 11, image 2 of 2
      • Remove the front fascia.
      Ask FixBot
    11. Valve Index Headset Motherboard Replacement, Remove the motherboard: step 12, image 1 of 1
      • Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
      Ask FixBot
    12. Valve Index Headset Motherboard Replacement: step 13, image 1 of 3 Valve Index Headset Motherboard Replacement: step 13, image 2 of 3 Valve Index Headset Motherboard Replacement: step 13, image 3 of 3
      • Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
      Ask FixBot
    13. Valve Index Headset Motherboard Replacement: step 14, image 1 of 2 Valve Index Headset Motherboard Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
      • During reassembly, be sure this cable is not trapped underneath the motherboard.
      Ask FixBot
    14. Valve Index Headset Motherboard Replacement: step 15, image 1 of 3 Valve Index Headset Motherboard Replacement: step 15, image 2 of 3 Valve Index Headset Motherboard Replacement: step 15, image 3 of 3
      • Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
      • Carefully disconnect the display cable connector.
      Ask FixBot
    15. Valve Index Headset Motherboard Replacement: step 16, image 1 of 2 Valve Index Headset Motherboard Replacement: step 16, image 2 of 2
      • Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
      Ask FixBot
    16. Valve Index Headset Motherboard Replacement: step 17, image 1 of 3 Valve Index Headset Motherboard Replacement: step 17, image 2 of 3 Valve Index Headset Motherboard Replacement: step 17, image 3 of 3
      • Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
      • Disconnect the FPC cable from the motherboard.
      • During reassembly, make sure this ribbon cable is not trapped under the motherboard.
      Ask FixBot
    17. Valve Index Headset Motherboard Replacement: step 18, image 1 of 2 Valve Index Headset Motherboard Replacement: step 18, image 2 of 2
      • Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
      • During reassembly, make sure this cable is not trapped under the motherboard.
      Ask FixBot
    18. Valve Index Headset Motherboard Replacement: step 19, image 1 of 3 Valve Index Headset Motherboard Replacement: step 19, image 2 of 3 Valve Index Headset Motherboard Replacement: step 19, image 3 of 3
      • Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
      Ask FixBot
    19. Valve Index Headset Motherboard Replacement: step 20, image 1 of 1
      • Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
      Ask FixBot
    20. Valve Index Headset Motherboard Replacement: step 21, image 1 of 2 Valve Index Headset Motherboard Replacement: step 21, image 2 of 2
      • Grab the motherboard by the USB port and carefully remove it from the headset.
      • During reassembly, be very careful not to trap any of the previously disconnected cables under the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
2 other people completed this guide.
Sam Omiotek
100,081 Reputation
289 Guides authored
5 Guide Comments
Where can I buy the motherboard? It doesn't look like ifixit has them.
Curtis Gray - Reply Share
I have this same question.
Patrick Hartge - Reply Share
you would think the replacement motherboard would be in the list of required items. Where are you supposed to buy this from?
Grant Za - Reply Share
Same question ,where do i get a replacement main board
Gifted Misfit - Reply Share
Daniel O'Sullivan - Reply Share
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 184
All Time: 14,893
