Valve Index Headset Head Strap Replacement
    1. Valve Index Headset Head Strap Replacement, Adjust the eye tube relief: step 1, image 1 of 1
      • Twist the eye tube relief knob clockwise to fully extend it.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: step 2, image 1 of 3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: step 2, image 2 of 3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: step 2, image 3 of 3
      • Insert an opening pick between the eye relief knob and the head strap.
      • Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
      Ask FixBot
    2. Valve Index Headset Head Strap Replacement, Reassembly tip: step 3, image 1 of 1
      • During reassembly, ensure the eye relief knob is aligned with the shaft before pressing it on.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Remove the head strap clip: step 4, image 1 of 3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: step 4, image 2 of 3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: step 4, image 3 of 3
      • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
      • Pry up on the head strap clip until it is unclipped from the head strap.
      • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Remove the face gasket: step 5, image 1 of 2 Valve Index Headset Head Strap Replacement, Remove the face gasket: step 5, image 2 of 2
      • Use your hand to gently pull the face gasket straight off of the headset.
      • The face gasket is held in place by four magnets that secure to screws in the face bezel.
      • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: step 6, image 1 of 2 Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: step 6, image 2 of 2
      • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
      Ask FixBot
    2. Valve Index Headset Head Strap Replacement, Disconnect the tether cable: step 7, image 1 of 2 Valve Index Headset Head Strap Replacement, Disconnect the tether cable: step 7, image 2 of 2
      • Pull the tether cable straight back out of the headset.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Head strap removal information: step 8, image 1 of 2 Valve Index Headset Head Strap Replacement, Head strap removal information: step 8, image 2 of 2
      • The head strap can be removed without removing the face gasket bezel if you have the correct length driver. If you are using your iFixit T6 driver, skip this step and proceed with removing the face gasket bezel.
      • Your T6 driver must have a shaft longer than 18 mm (0.7 in) and an overall length less than 140 mm (5.5 in).
      • Insert your T6 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
      • Skip to step 12.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Remove the face gasket bezel: step 9, image 1 of 1
      • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
      Ask FixBot
    2. Valve Index Headset Head Strap Replacement: step 10, image 1 of 2 Valve Index Headset Head Strap Replacement: step 10, image 2 of 2
      • Do not try and pry the face gasket bezel off, or you will damage the headset.
      • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
      • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
      Ask FixBot
    3. Valve Index Headset Head Strap Replacement: step 11, image 1 of 3 Valve Index Headset Head Strap Replacement: step 11, image 2 of 3 Valve Index Headset Head Strap Replacement: step 11, image 3 of 3
      • Repeat the previous step for the right side of the face gasket bezel.
      • Remove the face gasket bezel.
      Ask FixBot
    1. Valve Index Headset Head Strap Replacement, Remove the head strap: step 12, image 1 of 1
      • Use a T6 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
      Ask FixBot
    2. Valve Index Headset Head Strap Replacement: step 13, image 1 of 2 Valve Index Headset Head Strap Replacement: step 13, image 2 of 2
      • Pull the right end of the head strap straight off of the headset.
      • During reassembly, ensure the head strap is correctly positioned on the alignment post.
      Ask FixBot
    3. Valve Index Headset Head Strap Replacement: step 14, image 1 of 2 Valve Index Headset Head Strap Replacement: step 14, image 2 of 2
      • Use a T6 Torx screwdriver to loosen the screw securing the left side of the head strap to the headset.
      • Don't let this screw fall inside the headset. It is not a captive screw and is difficult to retrieve.
      • If the black plastic cap surrounding the cap limits access, use an opening pick to remove the cap.
      Ask FixBot
    4. Valve Index Headset Head Strap Replacement: step 15, image 1 of 2 Valve Index Headset Head Strap Replacement: step 15, image 2 of 2
      • Pull the left end of the head strap straight off the headset.
      • During reassembly, be careful not to let the screw fall into the headset. Use your driver to hold it in place from behind if necessary.
      Ask FixBot
    5. Valve Index Headset Head Strap Replacement: step 16, image 1 of 2 Valve Index Headset Head Strap Replacement: step 16, image 2 of 2
      • Slide the head strap band out from the headset.
      • The head strap is now fully removed.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
32 other people completed this guide.
Sam Omiotek
100,081 Reputation
289 Guides authored
8 Guide Comments
I'm having troubles with my left speaker, I just got done replacing it, is this the next step I wanna try in troubleshooting it? The last thing I want to do is buy a whole new headset? It cuts out when the strap moves. I've already replaced the cable as well.
Who? - Reply Share
Try to tighten left part of the strap (step 14)
Анатолий Прилуцкий - Reply Share
When will they be in stock again
lightning gaming - Reply Share
Any word on restocking for this part?
Charles Allen - Reply Share
No stock for 2 Years now. Great...
Ricky Bobby - Reply Share
Past 24 Hours: 38
Past 7 Days: 165
Past 30 Days: 829
All Time: 56,487
