Video Overview
This teardown is not a repair guide. To repair your Valve Index, use our service manual.
    1. Valve Index Chip ID, Headset Main Board Side 1: step 1, image 1 of 2 Valve Index Chip ID, Headset Main Board Side 1: step 1, image 2 of 2
      • Chip ID, part 1:
      • Lattice Semiconductor iCE40HX8K-CB132 iCE40 HX FPGA
      • Nordic Semiconductor nRF52840 Bluetooth low energy 5.3 SoC
      • EtronTech eSP776U FHD multi-camera ISP bridge
      • Winbond W25Q32JW 4 MB serial NOR flash memory
      • Analogix ANX7530 SlimPort 4K UHD receiver
      • Cirrus Logic CS47L35 audio codec w/ DSP
      • Nuvoton NPCA110PA0YX audio enhancing engine and codec
      Ask FixBot
    2. Valve Index Chip ID: step 2, image 1 of 1
      • Chip ID, part 2:
      • Microchip USB5744 4-port USB hub controller
      • VIA Labs VL671-Q4 USB 2.0 to USB 3.1 transaction translator
      • Texas Instruments LP8556SQ-E09 LED backlight driver
      • Texas Instruments LP5562 4-ch LED driver w/ program memory
      • Texas Instruments TS3A5223 2-ch. SPDT analog switch
      • Toll Microelectronic TMI3255T 5 A synchronous step-down converter
      • Texas Instruments TPS22915C 2 A load switch
      Ask FixBot
    3. Valve Index Chip ID: step 3, image 1 of 1
      • Chip ID, part 3:
      • Texas Instruments LP5907MFX-3.3 250 mA / 3.3 V LDO regulator
      • Texas Instruments LP2951-50 100 mA / 5.0 V LDO regulator
      Ask FixBot
    4. Valve Index Chip ID: step 4, image 1 of 1
      • Chip ID, part 4 - sensors:
      • TDK-InvenSense ICM-20602 6-axis MEMS accelerometer & gyroscope
      • Microchip AT30TS0x temperature sensor (likely)
      Ask FixBot
    5. Valve Index Chip ID, Headset Main Board Side 2: step 5, image 1 of 2 Valve Index Chip ID, Headset Main Board Side 2: step 5, image 2 of 2
      • Chip ID, part 1:
      • Microchip ATSAMG55J19B-MU 32-bit ARM Cortex-M4 microcontroller w/ flash - 32 kB
      • NXP Semiconductor LPC11U14 32-bit ARM Cortex-M0 microcontroller w/ flash - 32 kB
      • Winbond W25X10CL 1 Mb serial NOR flash memory
      • Macronix MX25L512E 64 KB serial NOR flash memory
      • Goodix TFA9892 13.2 W class-D audio amplifier
      • Texas Instruments TPS65132T6 dual output power supply
      Ask FixBot
    6. Valve Index Chip ID: step 6, image 1 of 1
      • Chip ID, part 2:
      • Texas Instruments TS5USBC41x USB 2.0 dual SPDT analog switch w/ overvoltage protection
      • Texas Instruments TS3USB30E USB 2.0 dual-channel SPDT analog switch
      • Texas Instruments TPS562201 2 A synchronous step-down converter
      • Texas Instruments TPS563209 3 A synchronous step-down voltage regulator
      • Texas Instruments TPS259571 eFuse w/ overvoltage protection
      • Texas Instruments TPS2H000-Q1 2-ch. smart high-side power switch
      Ask FixBot
    7. Valve Index Chip ID: step 7, image 1 of 1
      • Chip ID, part 3:
      • Texas Instruments TPS22970 4 A load switch
      • Texas Instruments TLV70728P 200 mA / 2.8 V LDO regulator
      • Nexperia 74LVC157A quad 2-input multiplexer
      • Texas Instruments TCA9803 2-bit level-translating bus buffer/repeater
      • Texas Instruments SN74AUP2G125 dual bus buffer
      • Texas Instruments SN74AVC4T245 4-bit dual-supply bus transceiver
      Ask FixBot
    8. Valve Index Chip ID, Left Controller Main Board Side 1: step 8, image 1 of 2 Valve Index Chip ID, Left Controller Main Board Side 1: step 8, image 2 of 2
      • Chip ID, part 1:
      • Nordic Semiconductor nRF52832 Bluetooth 5.3 SoC
      • Cirque 1CA037 touch controller
      • Renesas load switch (likely)
      Ask FixBot
    9. Valve Index Chip ID: step 9, image 1 of 1
      • Chip ID, part 2 - sensors:
      • Allegro Microsystems A1304 hall effect sensor
      Ask FixBot
    10. Valve Index Chip ID, Left Controller Handle Board Side 1: step 10, image 1 of 2 Valve Index Chip ID, Left Controller Handle Board Side 1: step 10, image 2 of 2
      • Chip ID, part 1:
      • Fitipower Integrated Tech FP6183-12X7 300 mA / 1.2 V LDO regulator
      • onsemi NCP161AMX330TBG 450 mA / 3.3 V LDO regulator
      Ask FixBot
    11. Valve Index Chip ID, Left Controller Handle Board Side 2: step 11, image 1 of 2 Valve Index Chip ID, Left Controller Handle Board Side 2: step 11, image 2 of 2
      • Chip ID, part 1:
      • Lattice Semiconductor iCE40HX8K-BG121 iCE40 HX FPGA
      • Texas Instruments BQ24297 3 A Li-Ion battery charger
      • Texas Instruments BQ27421-G1D battery fuel gauge
      • Renesas mixed signal array
      • Texas Instruments TPS630250 2 A buck-boost converter
      • onsemi NCP161AMX300TBG 450 mA / 3.0 V LDO regulator
      Ask FixBot
    12. Valve Index Chip ID: step 12, image 1 of 1
      Ask FixBot
1 Guide Comment
Is this repairable like the Steam Deck? Has Valve become a repair friendly company or no?
Square Penix - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 65
All Time: 2,828
