Valve Index Base Station IR Laser Replacement
  1. Valve Index Base Station IR Laser Replacement, Opening Base Station: step 1, image 1 of 2 Valve Index Base Station IR Laser Replacement, Opening Base Station: step 1, image 2 of 2
    • I have not found a way to remove the faceplate without damage
    • Score the front plastic.
    • Use the soldering iron to cut part of it until you can open it with pliers.
    Ask FixBot
  2. Valve Index Base Station IR Laser Replacement, Remove Plastic Guard: step 2, image 1 of 2 Valve Index Base Station IR Laser Replacement, Remove Plastic Guard: step 2, image 2 of 2
    • The top piece has a slop ramp and it is hard to get off.
    Ask FixBot
  3. Valve Index Base Station IR Laser Replacement, Remove Main Unit: step 3, image 1 of 1
    • Use a T8 screwdriver to remove the four screws that are marked with a blue circle.
    Ask FixBot
  4. Valve Index Base Station IR Laser Replacement, Take off Diode Laser Control Board: step 4, image 1 of 1
    • It is contact pins.
    • Use a T8 screwdriver to remove the three screws marked with blue circles.
    Ask FixBot
  5. Valve Index Base Station IR Laser Replacement, Pull Out IR Laser Diode: step 5, image 1 of 1
    • Use needle-nose pliers to pry out the piece marked by the blue circle.
    Ask FixBot
  6. Valve Index Base Station IR Laser Replacement, If using diode: step 6, image 1 of 1
    Ask FixBot
  7. Valve Index Base Station IR Laser Replacement, Insert 1.0 IR led: step 7, image 1 of 1
    • Line up the flat sides.
    • Then add hot glue around the diode case.
    Ask FixBot
  8. Valve Index Base Station IR Laser Replacement, Strip Wires: step 8, image 1 of 1
    • Very small wires.
    Ask FixBot
  9. Valve Index Base Station IR Laser Replacement, Solder IR Laser to IR Controller Board: step 9, image 1 of 1
    • Black PL1
    • Red PL2
    • White PL3
    • LD+ (1) is PL1
    • Case (2) is PL2
    • LD- (3) is PL3
    Ask FixBot
  10. Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 10, image 1 of 3 Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 10, image 2 of 3 Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 10, image 3 of 3
    • Follow start steps in reverse.
    Ask FixBot
5 other people completed this guide.
Omegakitty
253 Reputation
1 Guide authored
20 Guide Comments
Can you use HLD830030N5T, 5,6mm TO18 30mW 830nm Laser diodes as replacement or is the wattage different?
Thank you for the Info that the 1.0 Laser works in the 2.0 Variant!
Johannes Steinchen - Reply Share
TLDR, no you need 200mw to replace it.
The wattage for a base station laser is 200mW 830nm. With a 30mW I would expect the laser to immediately burn out because of constant current output.
Omegakitty - Reply Share
Thank you very much!
by any chance could you send a link to that exact laser please and thank you
xen isy - Reply Share
for instance would this work?
https://www.ebay.com/itm/166018393905?ch...
Past 24 Hours: 28
Past 7 Days: 201
Past 30 Days: 964
All Time: 14,569
