Up to 20% off select tools
VTechCS6719-16 Speaker Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
87
All Time:
777
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide demonstrates a walk-through of steps needed to completely dismantle the phone in order to locate the speaker and replace it with a new one.
    1. VTechCS6719-16 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Remove the sliding cover on the back of the phone case.
      Ask FixBot
    2. VTechCS6719-16 Speaker Replacement: step 2, image 1 of 1
      • Now remove the battery by lifting it and removing the two pin cable.
      Ask FixBot
    3. VTechCS6719-16 Speaker Replacement: step 3, image 1 of 1
      • Unscrew the two 10mm screws on the back of the phone base.
      Ask FixBot
    4. VTechCS6719-16 Speaker Replacement: step 4, image 1 of 1
      • Using the metal spudger edge along the phone and locate the hooks and latches.
      • Locating each of them apply a light but firm lifting force to release the front and back case.
      Ask FixBot
    5. VTechCS6719-16 Speaker Replacement: step 5, image 1 of 1
      • The front case should now be freed.
      • Put the front case aside for later.
      Ask FixBot
    6. VTechCS6719-16 Speaker Replacement: step 6, image 1 of 1
      • There are two 10mm screws located at the top of the circuit board.
      • Unscrewing the screws allows for access to the speaker.
      Ask FixBot
    7. VTechCS6719-16 Speaker Replacement: step 7, image 1 of 1
      • Flipping the circuit board will expose the speaker rested in the white LCD base.
      • Gently using the scoop end of the spudger will free the speaker from the dock.
      • Careful not to jerk the speaker as it is still attached to the board.
      Ask FixBot
    8. VTechCS6719-16 Speaker Replacement: step 8, image 1 of 1
      • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
      • If this is your first time soldering, check out this useful soldering guide.
      Ask FixBot
Author
with
Charles montes
513 Reputation
5 Guides authored
UMass Dartmouth, Team 5-5, Martin Fall 2016 Member of UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 777
