Up to 20% off select tools
VTechCS6719-16 Ringer Replacment
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
95
All Time:
803
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide demonstrates a walkthrough of steps needed to completely remove the old ringer and put in a nice working new ringer.
    1. VTechCS6719-16 Ringer Replacment, Ringer: step 1, image 1 of 1
      • Remove sliding back cover from case.
      Ask FixBot
    2. VTechCS6719-16 Ringer Replacment: step 2, image 1 of 1
      • Lift the battery and unplug the two pin cable from phone base.
      Ask FixBot
    3. VTechCS6719-16 Ringer Replacment: step 3, image 1 of 1
      • Slide back cover off the phone
      • Located at the bottom of the frame are the two-10 mm screws.
      • Use a Phillips head screwdriver to remove both 10 mm screws.
      • It is recommended to use a magnetic mat or place the screws on an easy to see surface. They will be needed when the phone is reassembled.
      Ask FixBot
    4. VTechCS6719-16 Ringer Replacment: step 4, image 1 of 1
      • After removing the two screws from the back of the phone carefully use the metal spudger to lift along the edges and raise the phone case from the internal clips.
      Ask FixBot
    5. VTechCS6719-16 Ringer Replacment: step 5, image 1 of 1
      • Once the case is lifted, the board should be freed except for the connection between the ringer and the case.
      • Be careful do not pull the case away from the phone in a jerking or aggressive motion.
      Ask FixBot
    6. VTechCS6719-16 Ringer Replacment: step 6, image 1 of 1
      • Using the spudger lift the latch over the ringer to release it.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
      Ask FixBot
    7. VTechCS6719-16 Ringer Replacment: step 7, image 1 of 1
      • The last component of the latch is soldered to the circuit board. This will take some soldering expertise.
      Ask FixBot
Author
with
Charles montes
513 Reputation
5 Guides authored
UMass Dartmouth, Team 5-5, Martin Fall 2016 Member of UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 95
All Time: 803
